Page 45 of 49
Re: kulluminati777 - 1993 MX-3 GS
Posted: April 22nd, 2014, 4:37 pm
by kulluminati777
Yeah those are the MS03's i like those wheels. I always wanted to get a set if I got another MX3. That set is rather expensive though. They do fit an MX3 like a glove but they were developed for the miata. I want to say they came out before the MS-01R roadster wheels and the Aspec kit stuff...
![Image](http://i.imgur.com/6bh34Oz.jpg)
Posted: April 26th, 2014, 3:44 pm
by kulluminati777
Posted: April 29th, 2014, 3:45 pm
by DeadMaker
Now these are VERY Rare..
Did jdm version had mx3 stump?
Posted: April 30th, 2014, 9:49 pm
by kulluminati777
Posted: May 3rd, 2014, 4:11 pm
by WhiteFinish
Good initiative but it needs some TLC
Posted: May 3rd, 2014, 8:39 pm
by wertys
i've seen your interest in the set of ms-03 wheels, they're my favourite IMO and if you can manage to get them, i'd defenitely look great on your car!
Posted: May 5th, 2014, 9:34 pm
by kulluminati777
WhiteFinish wrote:Good initiative but it needs some TLC
Hardy har har
. But as I said once my hand is better I will be redoing it. If i didnt put the second coat of resin on it would of came out perfect
wertys wrote:i've seen your interest in the set of ms-03 wheels, they're my favourite IMO and if you can manage to get them, i'd defenitely look great on your car!
There not to hard of a wheel to find. There ALOT more common than a MS01 or MS01S wheels.Maybe because they were MX5 roadster specific. There always on the japan auctions every single time I browse through them. Yeah if (most likely when
) I get a second MX3. I will go with those wheels I bet. Trying a 4CYL turbo my next MX maybe a wrap around spoiler and a youdirtyfox front for aesthetics
Posted: May 6th, 2014, 2:49 pm
by Josh
Wet block sand, then UV clear coat at least 3 coats and it should look just fine.
Posted: May 23rd, 2014, 7:53 pm
by kulluminati777
Posted: May 25th, 2014, 12:03 pm
by SuperK
PBlaster, nutsoff, and similar products aren't very effective.
My local shop gave me an excellent tip.
Mix acetone and transmission fluid and soak the bolt in that solution overnight. The acetone will penetrate the threads and feed the transmission fluid in. The acetone will then evaporate off so you don't accidentally light things on fire.
Then torch the bolts. you may be able to break them free without... breaking them.
Posted: May 25th, 2014, 12:29 pm
by crazycanadian
Good luck with the bolts...i managed to get the sub frame side loose but couldn't get the knuckle side loose on my car... ended up having to get new knuckles and bolts...
Posted: May 29th, 2014, 2:48 pm
by Nd4SpdSe
SuperK wrote:My local shop gave me an excellent tip.
I tried that once, they wouldn't mix and the ATF turned into globs at the bottom of the bottle.
Posted: May 31st, 2014, 12:29 am
by kulluminati777
I will try anything but I think my bolts at the subframe end will come out I didnt try them. I just tried the hub bolt and it did not move so I gave up. Maybe I can get away with just getting only new hubs for now.
Posted: June 2nd, 2014, 6:24 pm
by kulluminati777
So the rear end is on the back burner for now. Ill deal with it once I get a tad bit of cash and time to buy some rear hubs from the PnP.
But this weekend was monumental. With the help of the coolest guy I have met since being out here in california (Dan[sac]) I got the MS front sway bar on and by help I mean he did most of the work and I tired to assist lol.
I havent got a chance to really test out the bar just yet because I need new endlinks. I did ALOT of research on a bigger front bar because everyone knows the fundamentals of sway bar sizing and your drive train relationship and I dont think that applies to EVERY single vehicle as a standard. I think each chassis is designed different from what works for that car and what will work for the next. I found out eibach makes larger front sway bars for the FWD cars on its website and there the gurus when it comes to aftermarket suspension upgrades that are still streetable. The Integra type R. The greatest handling FWD chassis of all time has a 25mm front and 22mm rear bar and mazdaspeed engineers and drivers knew what they were doing when they tuned the car from the ground up. The fact that this car HAS to have every mazdaspeed piece in the brochure Unless there is something better adds to the bar going on the car as well.
It took awhile to drop the sub frame but not as long as I thought and once the old bar came off I was shocked at how light it was. So it is indeed hollow. I mean the MS bar is only so much bigger but it was easily 4 times heavier. Anyway here are some pics of this epic moment. I say that because I have been scouring the earth looking for this holy grail this seems to be the only front bar on the planet lol
. I have ran into tons of rear bars so those aren't hard to find but I have never even seen the front bar in pics or on the web or anything and say someone did have it, It takes ALOT of work to take it back off to sell it so the ones that did sell got crushed with the car or are still on and and someone has no idea what they have. I just got real lucky somehow.
A side by side comparison.
Minus the actual weight Dan and I had to double check I indeed have the real deal front MS bar.
OEM
MS
Then we got everything taken off the MS MX3. It was cool because we didnt have to remove the subframe all the way to the ground. Just lowered it a bit and slid the oem one out and put the MS one in. The endlinks and reassembling the traction bar is what gave the most trouble through the whole process
It looks like its right at home...
![Image](http://i.imgur.com/Hm4Pjzw.jpg)
Posted: June 3rd, 2014, 7:09 pm
by kulluminati777
