Sam's 1.6 MX-3- LT Turbo project.
WestcoastSpeeder
Re: Sam's 1.6 MX-3- LT Turbo project.
where did you but the mirrors and was it easy to install?
youdirtyfox
ebay, and yes screw straight up and just a few wires to the fender indicator for the mirror flasher and to the control unit to make the mirrors move up and down left and right.
youdirtyfox
Had a nice delivery from Oz. this morning, my adjustable wastegate bracket>
fits like a charm! Just the downpipe to make now and some more purchases, ie clutch and injectors and the kit is pretty much all there!
Had a quote for mapping the AEM piggyback of just under £400, so that's another expense to be factor in to the conversion, will be seriously looking into a street tune though using the laptop maybe depending on how difficult it looks to do.
those brocks are a great look, but holy positive camber batman!!!!
- MrMazda92
Oh weird, so they do have signals but only from the rear view? Would you plz post a picture from that angle?
youdirtyfox
Thanks, but positive camber, what?!?!mx3matt wrote:those brocks are a great look, but holy positive camber batman!!!!
@ Mrmazda like this:
http://www.mamotorworks.com/corvette-c5 ... -7125.html
youdirtyfox wrote:Thanks, but positive camber, what?!?!mx3matt wrote:those brocks are a great look, but holy positive camber batman!!!!
yay i just looked again and the poke made it look postive, looking closer that sheit is just about perfect lol.
youdirtyfox
Haha I knew would see it eventually. Im going to stick with the 215/40's and add just a flick of negative camber just so that tread
pattern tucks under the arch and with another -10mm off the coilovers I think she will be there
Tires are coming off the weekend then the wheels can be prepped for some refurb edges and paint!
- MrMazda92
Damn, I like this mirrors... I'm honestly thinking about getting a set of them now.
- fowljesse
You saw them on my car.
youdirtyfox
3SGE 315cc Toyota MR2 pink top injectors bought. Part no. 23250-74080.
Will want them to go for an ultrasonic clean before installing though. They are plug & play on the Miata, so here's hoping!
- fowljesse
Fingers crossed for ya!
- MrMazda92
I totally thought they were differentfowljesse wrote:You saw them on my car.
- Josh
Sam they should be plug and play since your car is B6DE you should already have oval injector plugs. Worse case is swapping the injector plugs
youdirtyfox
Had not seen your reply Josh as I didn't get a notification weirdly. Injectors have oval plug sockets so its all good
Pretty much decided on the downpipe flange now, just waitng for them to come into stock again.
Plan is to weld a plate over the oval hole, then ovalised one end of a 180 degree 2.5" pipe, then cut that exact oval shape out of the plate.
Although I think these type are made to take a 3" transition pipe ( oval to round in a very short distance)
Could do that but then it would need a cone reducer (which I have made just for the fun of it) down to 2.5"
which might push out the distance too much...
