Cant see it on here because the wireing schematics isnt uploaded but i have one at home.
In the enginebay fuse box theres a fuse "st sign" i think its called and its the starter output from ignitionswitch to ecu, its the only thing that fuse is for! Check it, its like a normal 10amp fuse.
If its blown, dont just put in another, try to find out why it blew in the first place.
The wire from that fuse to the ecu could be shorted out somewhere or otherwise if the fuse is allright you have a open circuit and you need to find out where its at.
Since your starter is turning and your not getting the start signal to the ecu it has to be one or the other unless you measured wrong
