thinking klze turbo
- RS_OBD'oh_2
Re: thinking klze turbo
as for the rx injectors.. IIRC the 550cc gen are low impedance. I would think the v6 are high impedance, so you would need to match it.
My hat is off to Spatial for taking the punishment, still asking questions and not
getting all offended. This thread is turning into useful info!
1994 MX-3 RS
Worklog: viewtopic.php?f=46&t=62251
B6 goodies for sale:
viewtopic.php?f=2&t=66333
2nd BP engine: http://www.clubprotege.com/forum/showthread.php?t=46695
- SpatialTerror
haha thanks. theres nice guys and guys that just try to make your day hard.
and if you really want somehting you just gotta push through the bs.
ive learned alot sence ive posted this.
and you all have been very helpful.
and im glad if this thread helps someone
SpatialTerror
SpatialTerror
- SpatialTerror
and where do i get millenia s injectors?
SpatialTerror
SpatialTerror
- marcdh
Mazda Xedos 9/Millenia 2.3 supercharged/miller cycle KJZEMSpatialTerror wrote:and where do i get millenia s injectors?
OR Probetalk!
View Worklog
View Worklog
- SpatialTerror
so am i looking at the right part here?
http://www.autozone.com/autozone/catalo ... =injectors
SpatialTerror
SpatialTerror
- pattheriault
check on ebay.. i saw some yesterday for around an 100$
heres the link: http://cgi.ebay.ca/Millenia-S-MX6-MX3-P ... 500wt_1182" onclick="window.open(this.href);return false;
- SpatialTerror
and do i have to get the bigger fuel rails?
or can i just use the ones i have?
SpatialTerror
SpatialTerror
These are a direct fit in your stock fuel rails.
- SpatialTerror
can i run them without the turbo? just on a n/a setup?
until i get a turbo setup
SpatialTerror
SpatialTerror
- Evo_Spec
if i'm not a total noob, i think the answer is yes you can, the only thing the number nominates is basicly the potential of the injectors, not how much their going to be pushing out all the time, so basicly the higher the number, the more potential you have for more power, type thing.
You can they will work.
But don't expect good fuel mileage or power.
They will be rich.
They will be rich.
A tiny little man lives in the top of the injector and talks to another tiny little man who lives in the ECU. All he does is open and close a valve. The higher the number, the more the injector flows per minute...all the time. The man in the ECU tells the man in the injector to hold the valve open for a specific duration based on that injector's volume. He doesn't know that you changed injectors so until you have the ability to tune the fuel map he will open the injector as if it was stock...only its not so you will get more fuel all the time.
The engine would run but I wouldn't install them until it's time. There is nothing to be gained and a lot of fuel to be wasted.
- SpatialTerror
so you would have to have like a megasquirt for the injectors to run the motor exactly right. but it will work on the stock setup. ok i was just curious.
because the first things im buying are the injectors, afpr, and the megasquirt.
probally gonna install that then just drive it setup like that for a little while till i get the rest of the parts
SpatialTerror
SpatialTerror
Thanks for asking good questions, when you starting your build SpatialTerror. Getting ready to sell some old parts to keep collecting for my build. MS is next. thanks for making a good thread
___________________
Black '92 GS [Project De-t Started!] [The spoiled one]
Green '95 1.6 [Daily][The jealous one...SOLD]
White '07 Mazda 3 GT [The pretty one]
[What can you say, I have a fetish for 3's]
mikeetown wrote: Do what you want to do dude cause in the end, your mx-3 is all about you.
