Project Jay-Spec MX-326GS
mikeinaus
Re: Project Jay-Spec MX-326GS
what kind of paint are you using on everything? is it some special auto paint that wont chip?
ive been fallowing this build for the past few days and its awesome. i really like the work your doing on this car. keep it up.
IMACHU2
Well lots of different paint. The Calipers / rear rotor hats / caliper brackets are all brush painted with Dupli-color caliper paint. The bottom of the car was painted with No name Rust-Oleum / Tremclad flat black with a brush. The inner fenders have spray rubberized rocker guard on them (usually ment for rock chip protection under the trim line). The front rotors came that way (Cad plate). Everything flat black is just no-name Rust-Oleum / Tremclad flat black from a rattle spray can. Everything aluminum was painted with a generic rattle can Zinc Chromate Yellow Primer, then painted with no-name rattle can Rust-Oleum / Tremclad flat black. Nothin' too fancymikeinaus wrote:what kind of paint are you using on everything? is it some special auto paint that wont chip?
Dominic Toretto's whip is a MaZda and his cell phone number starts in "(323)"
My work log http://mx-3.com/phpBB3/viewtopic.php?f=46&t=72471
IMACHU2
Worked on the car tonight. I put the rear bearings, rotors, calipers and S/S brake lines on.
- bbunkerc397
You've got some serious time on your hands.
1996 MX-3 KL-ZE with Eunos 800 IM, factory side skirts,. "Owner since 2001 my 14th year"
1992 929s 20B-REW Lowered, 17" chrome Millenia rims, custom black interior. "13th Owner 9th year"
2006 Chevy HHR LT "Bought Brand New - East Side Chevy" Sold to my Dad
IMACHU2
bbunkerc397 You've got some serious time on your hands.
I am single for the first time in a long time. I am going to take advantage of it and live at the garage until summer
Had fun at the shop today. Read about a dude that used cloths line for templates for wiring and plumbing. Figured I would give it a try. I would do it again, it was really helpful. I used painters tape and cloths line to "plumb" the brakes. I labeled the lines and took them to the parts store. I laid all the cloths line on the floor and matched it up to real brake line. Three of the lines were metric on one side and standard on the other. The proportioning valve was standard and so was the brake line tee I bought. I bought all metric lines and cut and flared the standard fittings on one end of them. I made brackets for the adjustable proportioning valve and came up with a clever spot for it. It fit perfectly in one of the drain holes. (lucky)
- Ryan
Don't you think that valve is a little far foreward? You'll have to be careful to to kick it every time you get in or out... it would be nice if it could move back a half foot, closer to the hatch popper.
IMACHU2
I have short legs, so it will 6" from the front of the seat. It is located in the same place as in the Mustang. I "test drove" it in my daily driver 323 It appears to be out of harms way. (duct taped it in the hole in the floor and drove around the block) LOL. It is is a no step zone when exiting. The only problem now is I had to look under my daily driver 323 a few time to understand and see where potential spacial conflicts would be. It is really, really scary under there
(the carpet is a structural member).
- PATDIESEL
- solo_ryder
Wow, you do some incredible work.. Everytime I see this WL it makes me happy seeing someone restore a 323 like this, with this level of detail. Good stuff!
- fowljesse
Clothesline?! What kind of wierdo would put parts on their car that aren't even auto parts?
Oh, yeah.
Me.
I would have found a way to actually use the clothesline as a brake line
I have to agree; Nice work!
I can't wait to see videos of it in action!
Oh, yeah.
Me.
IMACHU2
A dude named Pascal would disagree LOLPATDIESEL wrote:Just a note- you should consider making all of your brake lines the same legnth from left to right sides. Otherwise you'll get pull from the steering every time you brake
On stock Mazda brake lines you'll find a coil of brake line on the shorter side to make up for the difference in legnth. Usually right on the inside of the fender before it penetrates is where I have seen the coil of tubing placed.
Pascal's Law
Pascal's Law states that, because fluids are virtually non-compressible, any force applied to a closed hydraulic system will be felt equally and instantly throughout the entire system.
Why do brake lines have so many bends and loops?
You may think that the person who designed your brake lines was crazy, but all of those bends and loops have a purpose: They add flexibility.
Cars and trucks bend and flex as you drive. Many trucks have a frame that supports the body. The body is attached to the frame by rubber mounts, so there can be a lot of motion between the body and the frame. The master cylinder is attached to the body while some of the other brake components are attached to the frame. Also, when you step on the brake pedal, you flex the firewall of your car, moving the master cylinder but not the other components in the brakes.
A car is not always built with perfect accuracy. On one car the distance from the master cylinder to the anti-lock brake system pump will be slightly different from that on another. The extra flexibility added to the brake lines allows cars to be assembled even though they are slightly different from one another.
If the lines were short and straight, the motion of the car would eventually crack the brake lines; the continual flexing would fatigue the metal and eventually break it, just the way a spoon bent back and forth repeatedly will eventually break. By forming the brake line into a coil, the flexing in any one section is very small, and so puts almost no strain on the line.
Flow
While its true that flow would decrease pressure available at various distances from the source for things like water systems..the "flow" in a brake system is nil so the distances, number of elbows etc have no effect...pressure will equalize throughout the system. The only thing will be extra fluid in the system to take up extra length. Pressure in the closed hydraulic system will remain equal at all times. Your input/output force ratios will change when your input/output piston diameters change. The lines connecting to the pistons do not affect pressure.
Theory behind a proportioning valve:
At lower pressures, the prop valve effectively does nothing. At higher pressures, a piston separates the fluid at the inlet and outlet sides. No fluid flows through the valve. Therefore, the pressure locked into the system will remain constant at the preset (factory prop) or adjusted rate (as in an adjustable prop). Keep in mind the proportioning valve can be used to reduce brake line pressure, but will not increase it.
- _-Night-Shade-_
Genius. This guy knows his stuff
IMACHU2
I thought you would like that idea LOLfowljesse wrote:Clothesline?! What kind of wierdo would put parts on their car that aren't even auto parts?
Oh, yeah.
Me.
I would have found a way to actually use the clothesline as a brake line![]()
solo_ryder:Thanks. I am not looking to make a show car, just a car I can enjoy and tinker with without needing a tetanus shot and a de-greasing post tinker.
I was going to say something about the transmission of hydraulic force but I figured I've been the Clavin around here too long.
Your car is lookng great. I wish I had a parts store of my own.
IMACHU2
Me too LOL. I am the manager of a Speed Shop (not the owner). I does have its perks though.wytbishop wrote:I was going to say something about the transmission of hydraulic force but I figured I've been the Clavin around here too long.
