Page 5 of 5
Re: importer has confused me about my ECU.
Posted: May 23rd, 2009, 4:54 pm
by Whisper
Crap, where did you get the crimp connector for the ECU plug? I couldn't find one at RadioShack that's the right size - they're all too big.
Posted: May 23rd, 2009, 5:04 pm
by solo_ryder
Whisper, I just wired mine up.. Stole a connector from a old harness I had laying around
I put one of the wires to the ground by the little relays in the top pass corner there.. a 10mm bolt
Wired the other wire to the empty slot on the smallest plug on the ECU, 2G I think, but you will see the empty slot there. Tested it out and it works now.. car is really quiet haha
Posted: May 23rd, 2009, 5:35 pm
by Whisper
Alright, I managed to fab an ECU crimp to connect to 2G.
Unfortunately I don't have a spare harness, so I have no extra sensor plug. I'll just connect the wires directly to the sensor. Does it matter which wire goes to ground and which to ECU?
Posted: May 23rd, 2009, 6:20 pm
by solo_ryder
Well I grounded the pin that was on the passenger side of the sensor. The one closest to the driver side is the ecu one
Posted: May 23rd, 2009, 10:16 pm
by Whisper
Yay, success. I just copied the wire position from the primary sensor (and grounded where you said you did yours) and so far so good, everything seems to be working as intended, no CTS code, fans turn on and off at appropriate times. Although now idle is kind of all over the place, so I'll have to set TPS and IAC.
I can't really tell if it runs better or not, but at least it works.
Thanks for all the info, guys.
Posted: July 29th, 2009, 5:24 pm
by 94mx3precidia
Is it possible to get those pictures working again rx8?
Posted: July 30th, 2009, 3:28 am
by RX8SE3P
Pics fixed up now.
Stupid internet company changing the addresses and whatnot without ever telling anyone....
Posted: July 30th, 2009, 5:25 pm
by 94mx3precidia
This should be put into the FAQ titled "94 mx3 fan always on fix" or something like that. Ive been looking for this for a long long time and not my issue is fixed.
Posted: August 5th, 2009, 3:14 am
by Whisper
Yeh, should be a FAQ thing.
Posted: March 13th, 2010, 9:59 pm
by jakegaisser
I have a 94 MX3 with a KLZE swap, but we are using a 93 MX6 ecu. SOOOO we only have 1 thermosensor and the ecu throws a code for the other missing sensor. would it be possible to send the signal from the 1 thermosensor that I have to the pins on the ecu where the other thermosensor wires should be?? (This would solve that engine code i think)
