importer has confused me about my ECU.
Whisper
Re: importer has confused me about my ECU.
Post by Whisper »
Crap, where did you get the crimp connector for the ECU plug? I couldn't find one at RadioShack that's the right size - they're all too big.
solo_ryder
Post by solo_ryder »
Whisper, I just wired mine up.. Stole a connector from a old harness I had laying around
I put one of the wires to the ground by the little relays in the top pass corner there.. a 10mm bolt
Wired the other wire to the empty slot on the smallest plug on the ECU, 2G I think, but you will see the empty slot there. Tested it out and it works now.. car is really quiet haha
Whisper
Post by Whisper »
Alright, I managed to fab an ECU crimp to connect to 2G.
Unfortunately I don't have a spare harness, so I have no extra sensor plug. I'll just connect the wires directly to the sensor. Does it matter which wire goes to ground and which to ECU?
solo_ryder
Well I grounded the pin that was on the passenger side of the sensor. The one closest to the driver side is the ecu one
Whisper
Post by Whisper »
Yay, success. I just copied the wire position from the primary sensor (and grounded where you said you did yours) and so far so good, everything seems to be working as intended, no CTS code, fans turn on and off at appropriate times. Although now idle is kind of all over the place, so I'll have to set TPS and IAC.
I can't really tell if it runs better or not, but at least it works.
Thanks for all the info, guys.
94mx3precidia
Post by 94mx3precidia »
Is it possible to get those pictures working again rx8?
1994 MX-3 GS KLZE, Probinator, Bully stage 1 (probe GT), B&M Short Shifter, 2 1/4" Custom headders back.
RX8SE3P
Post by RX8SE3P »
Pics fixed up now.
Stupid internet company changing the addresses and whatnot without ever telling anyone....
1995 Eunos 30x KLZE
94mx3precidia
This should be put into the FAQ titled "94 mx3 fan always on fix" or something like that. Ive been looking for this for a long long time and not my issue is fixed.
Whisper
Post by Whisper »
Yeh, should be a FAQ thing.
jakegaisser
Post by jakegaisser »
I have a 94 MX3 with a KLZE swap, but we are using a 93 MX6 ecu. SOOOO we only have 1 thermosensor and the ecu throws a code for the other missing sensor. would it be possible to send the signal from the 1 thermosensor that I have to the pins on the ecu where the other thermosensor wires should be?? (This would solve that engine code i think)
