![Image](http://memimage.cardomain.net/member_images/5/web/245000-245999/245002_131_full.jpg)
![Image](http://memimage.cardomain.net/member_images/5/web/245000-245999/245002_132_full.jpg)
![Image](http://memimage.cardomain.net/member_images/5/web/245000-245999/245002_133_full.jpg)
![Image](http://memimage.cardomain.net/member_images/5/web/245000-245999/245002_134_full.jpg)
What yall think...other than OUCH.
i dont think thats cylinder wash, not at all. definatly too lean. the cams not being timed rite could cause it to not get the fuel when it was needed. it almost looks like the cylinder could have not been bored rite. but dont know that unless we actually see it. is the block still useable?cjthor wrote:could the scuffing be caused by the cams not being set right? toooooo rich causing cylinder wash?
many people blow or damage their built motors well under the limits it was built to handle because of driving it untuned or tuned wrong. running to rich can wash the oil off the cylinder walls causing excessive wear to the pistons, piston rings and cylinder walls. excessive heat at the ringlands and circulating microscopic shards of metal from cylinder walls is no bueno either. while this stuff may not immediately cause your motor to fail, the damage is already done before you brought your car to the dyno.cjthor wrote:could the scuffing be caused by the cams not being set right? toooooo rich causing cylinder wash?
Corksport built the motor, corksport improperly set the cams. I broke it in following their guidelines. 3k on the motor all varying RPM and not going into boost until 2k miles...even then i barely touched 5lbs.Steeb wrote:many people blow or damage their built motors well under the limits it was built to handle because of driving it untuned or tuned wrong. running to rich can wash the oil off the cylinder walls causing excessive wear to the pistons, piston rings and cylinder walls. excessive heat at the ringlands and circulating microscopic shards of metal from cylinder walls is no bueno either. while this stuff may not immediately cause your motor to fail, the damage is already done before you brought your car to the dyno.cjthor wrote:could the scuffing be caused by the cams not being set right? toooooo rich causing cylinder wash?
the built and unbuilt motors that last are ones that are broken in properly and tuned properly immediately following proper break in. if it is possible, dont drive your car if its not tuned, any driving on unproperly tuned or untuned fuel and timing maps causes damage even before it shows.
i should close this post until i get answers...you guys are helping but beating a dead horse. boils down to CORKSPORT said to drive the car at varying RPM for 3000 miles...THEY set my RRFPR and super AFC and said it was ok to run. THEY set the cams and THEY dyno tuned the car..THEY blew it up on the dyno..THEY are fixing it.Steeb wrote:
jarid, it is even more crucial that you tune immediately after break in because you did not start with a bpt w/ecu that had maps for boost that would have been closer to "optimal" fuel and timing maps than the dohc n/a b6 that came in your mx3. even if you had the bpt i wouldnt run more than stock power levels cuz many oem tune will dump the same amount of fuel after a certain psi.
for example, the normal stock boost on my mr2 turbo is around 5-8psi but the ecu will tell the injectors to dump the same amount of fuel @ anything over 10psi. oem ecu is only optimal for oem settings, anything higher than stock boost on a stock turbo'd motor is not optimal even tho it will run for a long time.
