yesh the vibration will be the mounts, ive got RR inserts and there is some vibration at idle. as for the intake are you just making an elbow or a whole box? if just the elbow you can get the ebay ones and cut them down to suit (like on my car) if thats an option. the rev's staying high is a vac leak or IAC issue, the first thing i would do is turn your idle screw down, i had the same problem once and turning the idle screw down a tad further fixed it. let us know how you go!
ive got most of November off work so ill probably be doing my engine then
