On the positive side.. At least you dont have to find room to store the car till their finished
Tunes67
I know the answer to none of these questions. Corksport is doing all the work on the engine .JWMotorsports wrote:Just out of curiosity what did they set your ring gaps at? If the gap is to small it can cause this to happen as well. When making big power you want the ring gap looser than stock as the pistons swell when heated. Also find out what they set the piston to cylinder wall clearance at. I know we did mine 0.0005" larger bore than wiseco called for on my coated pistons so the rings would have a larger gap and a hair more room for the pistons to swell as I'm looking to spray the piss out of it ontop of 30psi of boost. You don't want to go much more than that or you'll wear the walls and piston skirts out really fast. Its odd that only one cyl went like that though. Check the spark plugs to make sure cyl. 3 isn't burning a lot hotter than the other cylinders. All the plugs should look really close to the same. If not than your intake manifold design is to fault. I know your exhaust manifold isn't
ITS NOT THE TUNING IM UPSET ABOUT!!!!!!!!!!! IM UPSET CUZ THIS MOTOR HAS BEEN PROBLEMATIC!!Limegreen mx-3 wrote:osargeant wrote:Hey Jarid,
I find that most turbo 1600 Miatas with similar work tend to dyno in the 240-260whp range.
quote]
this miata with a bone stock 1.6 dohc engine made 334whp@25psi here's a pic on the setup TEC III, RM turbo kit, GT32, 550 RC injecters, other as well not bad for a bone stock B6 making that power. don't feel bad what do u have as far as tuning.
its a bone stock engine no aftermarket internals and no aftermarket camgears.hgallegos915 wrote:DAYUM over 300 WHP.. i would kill to get that power, thats a sexy engine.. i guess the cam gears are under those covers?
Nope....wish i did though..BuGS wrote:Do you have a custom intake manifold? Sounds like you have some flow issues. I wouldn't think that with the Microtech you should be having problems like that...
