Page 4 of 8
Posted: July 7th, 2006, 10:04 am
by atlantamx3
Barry,
I think I still have my complete B6 SOHC Auto wiring harness....
I cant check for it till after the weekend but I'd let you have it for cheap.
by mazdamx3sohc
just make sure the bp ecu if for an auto. everything else is plug in and you have to wire the one wire v.i.c.s. wire into the ecu on your own, you splice it in with the4th in from the top row i believe it is. i agree with you on not closing this but people are just basically coming in here to call me an idiot because i am somewhat of a beginner.
Posted: July 7th, 2006, 12:34 pm
by Custommx3
atlantamx3 wrote:Barry,
I have a DOHC Auto already.. I should be able to use mine since I will be using my own tranny.
Posted: July 7th, 2006, 1:01 pm
by MechaManZero
Barry I am pretty sure it was you, how is your newer BP swap doing? Aren't you the one going from the 94-95 B6 and going to the newer BP models?
Posted: July 7th, 2006, 8:08 pm
by mazdamx3sohc
so i guess we are still on for discussion on past swap experiences, what to expect good or bad what to remember that you might forget anything like that.
Posted: July 8th, 2006, 3:06 am
by Custommx3
I was going to swap a low mile b6, but the low mile ones have been sitting for over 7+ years. Never swaped a b6 nor BP yet, but do have 7 ZEs under my belt
Posted: July 8th, 2006, 5:53 am
by Juggalomastaxx
It should work on a 94 x-3 right?
Posted: July 8th, 2006, 8:09 am
by mazdamx3sohc
94 bp's are the easiest ones i have heard of.
Posted: July 8th, 2006, 12:25 pm
by ariesdude
Fact:
90-94 proteges have the old version of BP with the black valve cover which is a direct swap for 92-93 SOHC mx-3 (for 94-96 DOHC mx-3 wiring harness needs to be swapped as well)
Rumor:
95-98 proteges come with the newer version of BP with gray valve cover which is supposedly a direct swap for 94-96 DOHC mx-3 (wiring harbess swap may be needed for 92-93 SOHC mx-3)
Posted: July 8th, 2006, 12:39 pm
by mazdamx3sohc
keep in mind i also heard that because the down pipe is different that will have to be modified to fit on any of them. and you will have to have an 02 sensor hole welded on on some.
Posted: July 8th, 2006, 5:09 pm
by atlantamx3
mazdamx3sohc wrote:keep in mind i also heard that because the down pipe is different that will have to be modified to fit on any of them. and you will have to have an 02 sensor hole welded on on some.
Both BP's I have installed, the header bolted right to the stock MX-3 mid-pipe/ down pipe, whatever you want to call it. NO mods or welding or anything required.
Posted: July 8th, 2006, 9:33 pm
by mazdamx3sohc
hm..ok then. lol i know there is certain ones that dont bolt up.
Posted: August 8th, 2006, 6:41 pm
by Whitey
I have a 95 mx-3 and want to swap in a BP. I have read this whole thread but got confused. With me having a 95 do I or dont I need to do any electrical.
Posted: August 8th, 2006, 11:26 pm
by MechaManZero
Electrical isn't as bad as it seems.
Posted: August 9th, 2006, 10:28 pm
by Whitey
How many wires have to be spliced if any
