KLZE swap, some issues off the bat
Re: KLZE swap, some issues off the bat
Some people are unsure hence my request you clarify your suggestions ie. coolant sensor and IAC. Pointing people to the manual confirms what your saying and the manual also gives the parameters to confirm part serviceability. Burping the coolant system is always a good suggestion for sure.
