Honestly, on this one, I can shove proof down anybody's throat that I want to.wytbishop wrote:I catagorically disagree with that statement.
The North American Millenia 2.5L V6 is a KL-DE. Unless someone has evidence to the contrary, I believe it has the same piston and resulting compression ratio, as well as the same KL-01 cam as a North American Probe/MX-6/626. It has square intake ports and bigger injectors but as far as I know it is still rated to make 170hp. In an MX-3 with K8 injectors, a chipped ECU and JE-50 VAF and 2.25" or 2.5" exhaust with a standard EBAY header it would pull 145-150 on a chassis dyno. Same ballpark as any stock Probe/MX-6/626 DE you dropped in. It's a DE.
My Straight Neck JDM ZE with higher compression and KL-31 cam, chipped K801 ECU (Probinator claims he copied the KL31 map and "tweeked" it but that's another question), same VAF, same exhaust would pull 170-175. Countless members have done so. That's just fact.
Why would Probe/MX-6/626 guys have been swapping their DE's out for JDM engines all these years? If the Millenia engine was mechanically the same as the JDM ZE, straight, curved or otherwise, they would have been buying them up over here for a dozen years now. You would not have been able to find a Millenia with a 2.5L engine in it anywhere for a decade by now.
Look at KL131 heads and KL101 heads from the underside. The combustion chamber on the KL31 heads has less squish area than the KL101s, which is part of the .8 static CR bump that the "real KLZE" benefits from. Hey, wait, what other engine has KL131 heads!?
![Image](http://picardfacepalm.com/picard-facepalm-hotlink.jpg)
I'm dressed in NICE clothes right now, but if anybody wants to argue this point, I will change into grungy crap, and I will take one of my KL131 heads(from a '95 Millenia), and a KL101 head from a '94 626, AND FEED THEM SIDE BY SIDE PICTURES of the combustion chambers.
Charlie, this is SIMPLE.
A Millenia engine with J-SPEC TUNING and exhaust/intake specifications WILL produce more power than a "True KLZE" with Millenia(A-SPEC) TUNING and exhaust/intake specifications.
Why? The difference in power produced isn't magically created by a tiny difference in cam profile. You're an Engineer, for the love of God, why do you deny this?
