Josh's 94' GS - Updated 08/11/13
MrMazda92
Re: Josh's 94' GS - couple new pics
Post by MrMazda92 »
It's gonna look goooood! ;D
Post by Josh »
well this next month I will splurge for the paint and paint the front, USDM sides, the MS rear spoiler, and repaint my rear mudflaps :) its going to look great!
MrMazda92
Post by MrMazda92 »
Don't forget to post pics!
Whisper
Post by Whisper »
Hey man, good to see you're working on it and haven't completely riced it out yet. ;)
Gonna keep an eye on this, looking forward more updates.
Post by Josh »
Whisper wrote:Hey man, good to see you're working on it and haven't completely riced it out yet. ;)
Thanks, and no rice... Only clean and subtle. I would not do her wrong like that. No fart can no baller chrome wheels only OE Mazda parts minus that of the reproduction front :) But I will keep the rest just in-case I want to change it back.
kulluminati777
Post by kulluminati777 »
:twisted: YES! MORE MORE MORE PICS when u install all the MS body pieces i cant wait to see the MS kit installed on your whip...
Post by Josh »
Been a little wile since I updated so here it goes...
Some rattle can Ford Probe paint (as duplicolor no longer sells castle white).
Wiper Arms......
Whoops... looks like I forgot to snap completed pics of the blades... Well here is the plastic grommet for the rear wiper. I applied 3 coats of Plasti dip. the other rubber pieces I soaked scrubbed up and then soaked in conditioner and tire shine. :)
Since I decided to buy new MazdaSpeed Miata door handles why not try out the vents -_-
Keep in mind that only the right side vent is a direct swap. I dremeled the vent to make it fit :) I have two more to go so I will take progress pics on it.
side Projects
mmmmm 2.5" of mild steel goodness
I did just replace the 2 3/4" CIA with a proper full 3" but it is nothing fancy, yet... I will be done with the KLG4 IM soon and then I am going to do a proper 3" from the TB to the VAF and 4" from the VAF to filter with ram air... should be nice.
Thats it for now......
Oh wait, I got a KL36 ECU for the ZE... It can be viewed here :mrgreen:
http://www.youtube.com/watch?v=mIqFSygB8cY
Re: Josh's 94' GS - Short Vid Inside..
Post by Josh »
ok, more updated photos
Just the lip..
I have not finished attaching the weather stripping to the garnish lip but I will.
and the MS spoiler...
With the Mud guards...
Kind of get the idea with the rear wiper
The new toy :shrug:
haha NOT, I wish, was in the parking garage so I had to snap a pic. Red is so pompous... but its still pretty hot.
Next to come is the full length usdm sides and the MS replica front.... I was worried about the paint but the color match is pretty close maybe I should just roll with it rather then spend a $h!t load on some Castle white.
kulluminati777
Re: Josh's 94' GS - Updated 5/9/12
that garnish looks sweet with the MS wing :love: :love:
AaronTietje
Post by AaronTietje »
I thought long and hard about running just that garnish on my car, but in the end I cut it up to modify the spoiler you sold me. Looking good. :mrgreen:
RobMinhas
Post by RobMinhas »
Looking great Josh! I love the car! Looking so clean!
BTW, this may seem like a dumb question, but how do you get the passenger side vent out? I've been having trouble with it and I didn't want to force anything.
Post by Josh »
So the vent should rotate or the ring should rotate to one side or the other. I found that out when I just pried the hell out of mine to pull it out. :) luckily I did not break it. but it has taken a very precise hand with the dremell to cut out the holes just perfectly to get them to fit in. But I am happy with the end result :D
Post by Josh »
Dyno Run at CorkSport. new numbers in - up almost 10whp from previous time. 168.8WHP not bad not bad at all.
Only upgrades to motor are KL36 ECU, JE50 VAF, 3" intake from 2.5" and new mid pipe :)
http://www.youtube.com/watch?v=eQM69Eol ... r_embedded
Next step KLG4 intake mani and another Dyno run :D probably in September.
kulluminati777
Re: Josh's 94' GS - Updated 8/13/12 New Dyno results
dumb question but hp is alot different then whp?
so if something was rated 500 hp from factory the whp maybe less like 450?
Post by Josh »
Yep, you have your Crank Horse Power (which is factory rating) and Wheel Horse Power usually on a dyno like this one. Generally there is about a 20% loss from the crank through the drive train to the wheels. So that is why factory may rate a KLZE at 198 but they only dyno at like 150-160 at the wheels.
