Haha thanks but was just ribbing Ryan for the spellingwytbishop wrote:marcdh wrote: What's pre-prag anyway?
Pre-preg is CF fabric that has been pre-impregnated with heat activated resin. It is kept frozen by the manufacturer, but these days with newer resins that are only activated under heated pressure it has a shelf life of around 12 months at room temp. Even though you're not buying your own resin it is quite a bit more expensive than wet layup and can only be properly cured in an autoclave.
Charlie's no budget mid engine build: *Codename:BlakBishop*
- marcdh
Re: What's the highest performance FWD Mazda product out the
AZ-3 1498cc Turbo!  EVO 8 turbo and manifold, 5 stud swap, SSR Type C, DIYPNP seq Megasquirt
View Worklog
View Worklog
Re: Charlie's no budget mid engine build
doing a little quick conversion between yards and meters and GBP and USD...CF fabric is almost 20% more expensive over there than it is here.
- marcdh
There's a surprise...
   I imported 6x1m of it a few years ago from the USA for that reason.
View Worklog
View Worklog
I'm trying to find it, but several years ago, there was a guy who was making his own CF parts in his garage for his fox body mustang. He was doing hood, doors and was even going to do the roof I believe. Sadly I can't seem to find it, guess it's been that long ago. I'll keep on trying to find it for ya.
In looking for it, I've found other similar projects, may give you some good info
http://corner-carvers.com/forums/showthread.php?t=30257
(pics are gone, but there's still some good info posted)
http://forums.corral.net/forums/lounge/ ... oject.html
Man I've read so many CF threads on so many forums in the past 3 weeks I can't even remember half of it. The volume of educational resources available out there is staggering. I was brousing Demonoid looking for books on composite manufacturing and found a torrent from some engineering student or other who digitized his entire library of engineering literature and uploaded it. Racecar suspension design and chassis textbooks. A bunch of materials engineering texts...some of which are well over my head.
I saw a wicked how to on a Mustang forum of a guy making CF doors for his mustang dragster. he molded the skin and then made a two part mold of the inner structure. Very very helpful.
Did you read about that all-aluminum Shelby Cobra? You'd love the suspension design on it.
Well Charlie I have to say so far you've definitely covered your bases regarding composite work.  I wonder if you searched your area you might find a shop that wouldn't mind letting you use their facilities for an honourable mention some where on your car and on the internet?  Have you looked into kevlar at all.  That stuff is difficult to work with but man it's strong when your done.  I bloodied both my hands (blisters) cutting the stuff then I heard of water jets.     Anyway I'll be watching your progress, you definitely have your work cut out for you.  Cheers
I have read a bit about adding a layer of Kevlar for added toughness and abrasion resistance. Pagani has a new weave CF that includes strandes of Titanium. I have read that the tensile strength is through the roof.
I have to keep in mind that I am very very early in the process. I still have a tonne to learn and lots of design work left to do.
I do appreciate all of your input.
http://www.kirkhammotorsports.com/galle ... assis-book
http://www.kirkhammotorsports.com/book_aoe/aoe_12.pdf
I had a quick look at their website yesterday. I had never seen or heard of this car before. It's pretty cool. A little too shiney for my taste, but cool.
- ethand
that car looks....
As for your design, Charlie... Do this one!
'92 JDM Eunos Presso - Zeke
Not even close. But thanks for the input.ethand wrote:As for your design, Charlie... Do this one!
Ok, here's Charlie's project with the 'moonfinish'. Better?
Not funny.
Grills typically look tacky, no matter the car, but also depends on how it's done, but sometimes it's a protection thing, I know I can get them for the 8 to protect the oil coolers, but to consider mesh as part of the styling is, IMO, most of the time not nice looking. The only mesh my MX-3 had was in the small section of the bumper right under the hood, and it was painted black with a touch of teal to make it less conspicous.ethand wrote:and it doesn't even have any mesh in the grilles...?
