Page 3 of 3
Re: KLZE pistons, rods, etc
Posted: April 16th, 2009, 9:55 am
by kast2L
Nd4SpdSe wrote:with 11.5:1 pistons they would of your timing is off
hey nd4spd are you boring it to 20 or to 40? A friend that is a mechanic said that may be a bit over board and that most don't do past 30 so just wanted to know what your plans were again.
Posted: April 16th, 2009, 10:49 am
by Nd4SpdSe
20 is common, you can even get MazdaSpeed ones but their DE compresion
Most people that have overheating issues are 50-60 over
I'm going 40, I think it should be the largest where if there are overheating issues, it should be solvable...
Posted: April 16th, 2009, 3:43 pm
by kast2L
Nd4SpdSe wrote:20 is common, you can even get MazdaSpeed ones but their DE compresion
Ahh okay okay cause I hear different s--- about it and thats why i wanted to get the block sleeved to help with the cooling, but people on probetalk.com were saying it probably cant be sleeved and shouldnt need to be sleeve, but i rather be safe than sorry. I know it would cost an arm and a leg but it would be easier on the motor.
Posted: April 16th, 2009, 4:18 pm
by wytbishop
Typically auto metric makers offer oversized pistons for rebuilding your engine at .5, 1.0 and 1.5mm over stock. a 1.5mm oversize piston equates to a displacement increase of only 89cc. It will have no effect on performance.
A 4mm oversize would have an impact on performance. That would give you an additional 250cc-ish. Add the Paeco stroker kit and you've got 3L easy.
Posted: April 16th, 2009, 4:24 pm
by kast2L
wytbishop wrote:Typically auto metric makers offer oversized pistons for rebuilding your engine at .5, 1.0 and 1.5mm over stock. a 1.5mm oversize piston equates to a displacement increase of only 89cc. It will have no effect on performance.
whoa whoa we have a stroker kit for our car? I've been searching for days for one and haven't found one. Nvm i found it, god damn its expensive but i dont need pistons because it seems like that is part of the price or would I be better off just doing the kit through them but i dont htink they provide rods.
Posted: April 16th, 2009, 5:09 pm
by wytbishop
IT is expensive and I've heard bad stories about their service. I read about a Probe guy that waited many months for his stuff. I exchanged a series of emails with him a while back. He's a smart engine guy but he doesn't know anything about our cars.
OH and you can get just the crankshaft for $1500 but you would need new rods. If you buy the kit it comes with pistons that allow you to use stock rods. kind of a trade off.
Posted: April 17th, 2009, 5:01 pm
by kast2L
hey i found some valves i wanted to buy on importperformanceparts.net and wanted to know if can buy the valves for a mazda 626 2.5, because the series for the motor is KL so i figured it would fit in a klze, didnt want to order it and be wrong and how many should i be ordering?
Posted: April 17th, 2009, 5:06 pm
by Nd4SpdSe
Yep, exactly
12 Intake
12 Exhaust
