V8KOMX3 wrote:hey waax I have a question for you as I am having the same problem. When you say your disty was in the wrong position did you just take it out and change the direction of the ears on the back? I tried that with mine and found mine to only go in one way....
Like Savin said, I was refeering about the actual rotor that spins inside the distributor right under neath the cap. You can put it on 3 different ways considering its a triangle fitting. When I took my old coil out I must have not put the rotor on in the right position.
Hope this helps.
