Microsoft Windows XP [Version 5.1.2600]
(C) Copyright 1985-2001 Microsoft Corp.
C:\Documents and Settings\Nadia>ipconfig/all
Windows IP Configuration
Host Name . . . . . . . . . . . . : toshiba-user
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Mixed
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
DNS Suffix Search List. . . . . . : hsd1.wa.comcast.net.
Ethernet adapter Wireless Network Connection:
Connection-specific DNS Suffix . : hsd1.wa.comcast.net.
Description . . . . . . . . . . . : Atheros AR5004G Wireless Network Ada
pter
Physical Address. . . . . . . . . : 00-11-F5-0F-24-BF
Dhcp Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
IP Address. . . . . . . . . . . . : 192.168.1.101
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : 192.168.1.1
DHCP Server . . . . . . . . . . . : 192.168.1.1
DNS Servers . . . . . . . . . . . : 68.87.69.146
68.87.85.98
Lease Obtained. . . . . . . . . . : Monday, December 31, 2007 8:19:49 PM
Lease Expires . . . . . . . . . . : Tuesday, January 01, 2008 8:19:49 PM
Ethernet adapter Local Area Connection:
Media State . . . . . . . . . . . : Media disconnected
Description . . . . . . . . . . . : Realtek RTL8139/810x Family Fast Eth
ernet NIC
Physical Address. . . . . . . . . : 00-02-3F-D8-2C-94
fixing wireless connection
- mitmaks
Re: fixing wireless connection
s---, that confused me lol
still have that wireless issue??? at this point i would try to either do a system restore or perhaps uninstall your wireless card driver and reinstall it. to do that you could go to start right click on my computer click on properties, then hardware then device manager, under device manager you will need to expand the network adapters, right click on your wirless driver and click uninstall, you could try to install an updated version from the net, or you could simply restart the system and the driver will reinstall itself. if that does not fix it, its either that your card is bad, or your neighbour's router sucks..
