Mx-3 ZE On 4.11:1 Tranny = Slower?
- jschrauwen
This very subject came up at a meet / brunch we had in Toronto yesterday. Now I'm starting to doubt my original perception of final drive ideas.
To make it simple;
At a given speed (lets say 120kph) the rpm's of the MX3's 3.83 final drive is approximately 4000rpm.
Now, at same given speed (120kph), an MX3 fitted with a 626/MX6 tranny with a final drive of 4.11 - are the rpm's going to increase (higher than 4000rpm) or decrease (lower than 4000rpm)?
This is based on an assumption that the 1st through 5th gearing is identical in both tranny's. (they are, aren't they?)
To make it simple;
- papa roached
the higher the final drive ratio the more RPMs your gonna run and the lower the gearing
- tehbrookzorz
Obviously I've been a little delusional myself.
http://en.wikipedia.org/wiki/Gear_ratio
When I've been thinking of a taller gear ratio, I've always been thinking of the vehicle going faster with the higher number, whereas it appears the acceleration should be faster and the rpm's higher for the same relative speed.
What I want is to bring my revs down in the top gear, making my revs around 2500 rpm at 100 km/h, and also extending my top speed.
Cody
Your stock diff is a 4.39 final drive, the kl diff is a 4.105 (4.11).jschrauwen wrote:This very subject came up at a meet / brunch we had in Toronto yesterday. Now I'm starting to doubt my original perception of final drive ideas.
To make it simple;
mabe te auto trans is a 3.83 but i have never senn that ratio.
mx3 gs stock 4.39 diff = higher reves at same speed in all gears
kl 4.11 diff = lower revs in all gears at same speed
JUDGE ME ALL YOU WANT
93 gs, klde swap, kl trans, strait 2.5'' ehaust, euro front bumper, cold air intake, hei ign ,50 shot &
9.60s n the 8th mile so far 8.50s sprayn now
150 shot
150 shot
- mx3autozam
john you are wrong the mx3 drive is 4.39 not 3.83. when we were at taht meet thats why Tom was aying the mx6 would ahve shorter gears and we were all lost. lol we had the wrong numbers man mx3 is 4.39.jschrauwen wrote:This very subject came up at a meet / brunch we had in Toronto yesterday. Now I'm starting to doubt my original perception of final drive ideas.
To make it simple;
93 Mazda MX3 KLZE Turbo
- mx3autozam
yeah the higher the number the more low end torque it has makin it quicker off the line but you run out of gear faster at the end ruducin your top speed. the mx6 tranny will have a higher top speed in our cars over our trannies. which makes them faster but us quicker
http://www.gears-manufacturers.com/gear-ratios.html
- lowridah313
thank you all who were at the toronto meet, i told you i was right the web site john put up was my research. lol
Representin' the THRE3:TH1RT3EN
'02 Nissan Xterra SE, atx, 4x4, 32's
'92 Geo Tracker atx, 4x4
Feedback http://mx-3.com/phpBB3/viewtopic.php?f= ... 54&start=0" onclick="window.open(this.href);return false;
- mx3autozam
- jschrauwen
Thanks John!! I knew I got it from somewhere.mx3autozam wrote:john you are wrong the mx3 drive is 4.39 not 3.83. when we were at taht meet thats why Tom was aying the mx6 would ahve shorter gears and we were all lost. lol we had the wrong numbers man mx3 is 4.39.jschrauwen wrote:This very subject came up at a meet / brunch we had in Toronto yesterday. Now I'm starting to doubt my original perception of final drive ideas.
To make it simple;
So, I guess I was wrong and right at the same time.
Wrong about the exact gearing but right about switching to a 626/MX6 tranny and being able to bring the highway speeds rpm level down by about 800 rpm or so. Besides, I don't "live my life a quarter mile at a time" anyway.
top speed
man i just wanna know which has a higher top speed mx6 or mx3 tranny??? i like bimmin on the highway not draggin...
- jschrauwen
Re: top speed
MX6/626 = higher top speed (more or less) than the MX3/PGT. Meaning that at 120kph with an MX3 tranny your spinning about ~ 4000rpm. Swap in an MX6/626 tranny and bring those rpms down to about ~ 3200/3300rpm at the same 120kph.Hayata wrote:man i just wanna know which has a higher top speed mx6 or mx3 tranny???
hgallegos915
why do you want to go that fast?? I guess better fuel milleage? most of us already get between 25 - 30 miles per the us gallon..
-hec
- tehbrookzorz
- lowridah313
ummm......kph stands for kilometer per hour same as km/h
