Rattling Shifter... annoying vibration.
- rebel_princess_lynz
- corbanbrook
Tried to do mine before i left for montreal, but both bolts were too rusted to budge, was able to get one of the nuts off, but the rest just started to strip as i cranked on them.. sprayed some WD-40 in to let it soak for next time when I try this. I did tighten the bolt at the bottom of the shift rod as a tempory fix and the rattle went away, shifter is a lot tighter and gear paths are easier to slip into. After driving to montreal it loosened to the point where the rattle and looseness started coming back.. but at least i know thats what the problem is.
92 MX-3 1.6L 4 Cyl SOHC
MPG: 21.5city/38hwy
MPG: 21.5city/38hwy
- corbanbrook
