Been a while since an update. Been busy working and working on the Mx-3
Tranny project is moving along well, everthing is in order at the moment, just waiting for powdercoating to be done (which I was suppose to call today but forgot) and get my parents to pick them up and bring it to my mechianic to start the re-assembly. Here some pics of what I'm getting powdercoated:
Tranny case and housing:
Valve Coves:
And an intake manifold, not getting powdercoated however, it will be staying polished (big thanks to my dad for polishing it!):
Powdercoated is being done by a shop in St Catherines, estimate around $200 with another shot of being blasted because it oxydized after the last one while sitting.
Performance Powdercoating
13 Seapark Drive, Unit 8
St. Catharines, Ontario L2M 6S2
(905) 687-8183
Also got my MazdaSpeed Protege LSD welded and balanced. Although doing research it was highly recommended to get it balanced, I didn't come across any who actually did. It's quite convinient, the powdercoating, welding and balancing places are all really close together. Cost me $60. Was preheated for the weld and he even wrapped it to let it cool slowly, took over 12 horus to cool actually, but this guy knew exactly that I needed done, was quite impressed.
Here's a pic of the LSD welded
It was done at Canadian Custom Fabrication
11 Seapark Drive, Units 3&4
St. Catherines, Ontario, L2M 6S5
905-688-9555
I don't have pics of the balanced LSD, yet. My parents picked it up for me since it took a bit, they didn't know if they could because of the shaft inside the LSD apparently not being able to put it on the machine, but they did anyway, so I'm quite happy about that. Cost me $40
It was done at Fioravanti Custom Engines
620 Welland Ave.
St. Catherines, On, L2M 5V6
905-641-5448
There's some pics that I didn't take, so here's a few more thing's I couldn't post:
- New (yep, got another set) of MazdaSpeed motor mounts. However those will be polyfilled, haven't been done yet.
- B&M Short Shifter
- Fidenza Flywheel
- Clutchmaster Stage 3 Clutch
Unfortunately on my drive back for my week off, I was driving the Mx-3 home and the slave cylinder failed while I was in Washington D.C. (Of course if decides to fail then :S). So after a tow back, I dropped her at the shop which couldn't get her ready until next week, she needed a clutch line as well since it colapsed because of the dead slave cylinder, although there was slave's in stock around, the clutch line was special order, so I ordered a new stainless steel clutch line from CorkSport and would drop it off when I returned.
The guy in the first pic is Dave, a co-worker that wanted to ride back with me, but unfortuantely got stuck through the ordeal, but was a really good sport about it, tad too optimistic tho. And here a pic of the rental I had for my week off, not bad for US$21/day unlimited milleage (Put on just under 2000 miles). Was actually a fun car, first time driving a convertible actually too. V6 auto.
I got new, and I mean *new* leathers seats from J-Beef at the Mississauga Mazda Meet back in May. They are abslutely gorgeous. I have the rears as well from him, but I didn't bother swapping them in at the moment, they're sitting back in Niagara at the moment. Unfortunately I sacrifice the "heated" seats for these, but it was well worth it, and will be fixed sometime before the cold I hope.
Thanks again J-Beef!
Also, thanks to Mooneggs (thanks immensely man!) I got a front fog light switch. I'm so happy on how well it looks, cleans it right up. Much better than that ghetto blue switch from Radio Shack I had. Modded it with a blue LED, of course
As well, I finally implemented a rear fog light. The switch is easilly found in an Escort GT. Put in a blue LED as well
The wiring for the rear fog light. I was tempted to do both inner tails, but in the end, I decided to only do the inner drivers side, as per JDM/EDM spec. Here's a few pics. I'll post up a write-up on this later; possibly sometime this weekend. I wired them up so it's only allowed to get turned on when the running lights are on. It does not affect the runing light on that light, or the brake light when the fog isn't activated. Essentially it *is* the brake light when activated.
No Lights:
Running Lights:
Running Lights w/Fog Light On:
And one more thing to add, I'm currently in the Megasquirt Group Buy. Deposit is sent. Getting their "Deluxe" version. V3 board with coil pack support.
http://forums.probetalk.com/showthread.php?t=1701233196
Hehe, "that's all" I got for now. Hoping to ge the tranny in for mid-August, can't wait
