progress of my turbo 2.5 mx-3
- babyblueMX3
on 15 psi I don't think I'll have a problem hitting 350whp..that's my goal..once I'll hit it, no more modification..costs too much for a poor guy like me
RIP 400whp ZE-T MX-3
- MX-3 Money
Mnemonic
what are you doing about axles?
i only thought companies made them to handle 300hp i know that everyone believes that the stock wont handle that amount of hp
01 Lexus Is300 (LS2 Project)
93 Mx3 SE 2.5 KLZE (sold it)
- babyblueMX3
they are already taken care of..I broke one last year with my ze..Got a axle manufacturer here that made me custom ones to handle the power..lifetime warranty
finally and most importantly:D
your tranny.... is it still stock?
- babyblueMX3
yeah it is
but many have proven that the tranny can take a lot of beating..jeff abram had the stock tranny, so does rebel2k4 and many other that has a lot of power..
I'll slowly begin to build another one that will take a $hitload of abuse...with a lsd differential that is
nice:) make sure when you rebuild you have the custom 6th gear put in place:D
and the optional paddle shifters which you can turn off and on when you want to use the stick or the steering wheel
HEHE sweeett
HEHE sweeett
- MX-3 Money
I don't think anyones asked this, but what compression ratio are you running. I assume you had to lower it cuz if not....BOOM! lol And if so how did you change it? Different heads? Thicker head gasket?
1993 MX-3 GS 5 spd, KL-ZE swap, kl31 ecu, 110 amp alternator, Unorthodox Underdrive Pulley, SSautocrome headers, High flow cat, Pacesetter high flow cat-back, B&M shortshifter, Clear Sigs/Sides.
- babyblueMX3
8.7 compression ratio...everthing lies in the pistons
- babyblueMX3
I just install the rest of the stuff...I'll try to snap pics of the downpipe for ya if I can today
- babyblueMX3
- XxantwawnxX
Man, that makes the hairs on my butt stand up....nice job.
- babyblueMX3
yeah I'm making a heat shield for the disty and wrapping the exhaust
