HID Retrofit kits?
bubbaflaat
Re: HID Retrofit kits?
Has anyone put 9007 bulbs in our stock headlights? would they do much difference. I know they have a little bit different wattage.
THIS USER HAS BEEN BANNED, DO NOT DEAL WITH HIM. - MX-3.com Admin
With 9007's you will have a screwy beam because they are an axial filament and 9004 are transverse. I don't think anyone have tried yet. If you are gonna do that may as well try anything in between: 9005/9006, H4, H1, H2, H3, H7, H9. Although only H4 is another dual filament bulb from the set. May be one these will produce a decent enough beam, although I doubt that, because 9004's use whole 360 degrees of the reflector to make a beam, but the rest of them use only the top portion for the low beam.
bubbaflaat
Wow you know alot about lighting!! I love it! Well cool. I could care less about low beam. Just so I can see at night on high. An H4 would make a better beam on high. But would be kinda wacky on low beam you thing? Of course i'd have to do some crap to get them to fit but yeah...
