Hmmm.... streetthismx6 had just about every mod possible, cams, high comp pistons, etc. and only put down 196 whp....Originally posted by curve:
that is an old list of some of the things done to it. It know has a 5 angle valve job. Ported and polished heads. cams have been reground. Titanium valves and springs. Its make 275 cranck hp off the bottle and 400 chp on it.
Not saying that it cant be done, just saying streethis is the highest HP I have heard of n/a from a KL. Got a dyno chart? Id be curious to see the curves as well.
Whatever the case may be, nice times. Do you ever have troubles keeping trannies together? What 60' do you run?
If you ask me, turbo is the way to go. I bet I built my kit for less than you spent on your heads with cams.
<small>[ July 20, 2004, 12:25 PM: Message edited by: rebel2k4 ]</small>
