Page 3 of 3
Re: to those who need to replace o2
Posted: April 4th, 2004, 12:36 am
by lakersfan1
Well, I'm going to have to take away any endorsement for the 1 wire conversion now. While my MPG is up slightly - 1 MPG, I went for a smog check today, and I failed horribly because I was running too rich. I checked the sensors when I got home with a multimeter, and the voltage is crazy at idle. It's fluxuating all over the place. I'm going to need to go back to 4 wire sensors. :mad:
Posted: April 4th, 2004, 2:42 pm
by Bradmx32003
I had a feeling someone was going to say something like this.... ah well i knew it was going to be to good to be true actually SAVING money fixing this car haha
Posted: April 4th, 2004, 3:08 pm
by lakersfan1
Well, at least the write-up is still valid for 4 wire universal sensor installation. So I guess I didn't completely waste my time. :shrug:
Posted: April 5th, 2004, 12:08 am
by Bradmx32003
Also, its now only a 5 minutes job... and no way i cna screw that up.. just more expensive and now its gonna cost me the same amount haha.
Posted: April 8th, 2004, 11:18 pm
by esoterikest
my sensors are bad... i'm leaving them alone.
Posted: April 9th, 2004, 8:42 am
by TsiMiata
Thats what it is suppose to do. theres nothing wrong with what your seeing.
Was your emissions test an idle or load test? If it was an idle test O2 sensors wouldn't effect the test. The ECU ignores the O2 sensors at idle. It only uses the O2 sensors to adjust the mixture at steady state cruising.
<small>[ April 09, 2004, 07:51 AM: Message edited by: TsiMiata ]</small>
