to those who need to replace o2
lakersfan1
Re: to those who need to replace o2
Well, I'm going to have to take away any endorsement for the 1 wire conversion now. While my MPG is up slightly - 1 MPG, I went for a smog check today, and I failed horribly because I was running too rich. I checked the sensors when I got home with a multimeter, and the voltage is crazy at idle. It's fluxuating all over the place. I'm going to need to go back to 4 wire sensors.
Bradmx32003
I had a feeling someone was going to say something like this.... ah well i knew it was going to be to good to be true actually SAVING money fixing this car haha
Red 1992 Mx-3 GS, all stock.
lakersfan1
Well, at least the write-up is still valid for 4 wire universal sensor installation. So I guess I didn't completely waste my time.
Bradmx32003
Also, its now only a 5 minutes job... and no way i cna screw that up.. just more expensive and now its gonna cost me the same amount haha.
esoterikest
my sensors are bad... i'm leaving them alone.
TsiMiata
Thats what it is suppose to do. theres nothing wrong with what your seeing.Originally posted by lakersfan1:
Well, I'm going to have to take away any endorsement for the 1 wire conversion now. While my MPG is up slightly - 1 MPG, I went for a smog check today, and I failed horribly because I was running too rich. I checked the sensors when I got home with a multimeter, and the voltage is crazy at idle. It's fluxuating all over the place. I'm going to need to go back to 4 wire sensors.![]()
Was your emissions test an idle or load test? If it was an idle test O2 sensors wouldn't effect the test. The ECU ignores the O2 sensors at idle. It only uses the O2 sensors to adjust the mixture at steady state cruising.
<small>[ April 09, 2004, 07:51 AM: Message edited by: TsiMiata ]</small>
91 Eagle Talon Tsi AWD *RIP*
