I'm a vodka man myself, maybe some crown on the odd occasion. You should start a company with all these products you're making for us!wytbishop wrote:I hate beer.
[FS] Polyurethane Bushings
Re: [FS] Polyurethane Bushings
1993 Blaze Red SE, 17" blackie's, b+m sts, 45 deg 3" exh pipe/intake tube, K8ZE, aftmkt probe headers, magnaflow hi-cat, all 2.5" piping, magnaflow muffler.
1976 Datsun 620 p/u, full airride, Firestone 2600`s, 16ga fuel cell, Optima yellow top, AZ compressor, custom tubular frame with 9in step notch, 18" 100 spokes
1955 Willys Overland 4x4 P/U, '78 LT1 350 cu.in, fully restored.
- umcamara
You had me at hello Bishop. But now you've lost me...
I had a bad experience on my graduation day.
I'm a born and raised Calgarian. It was May 25th, 1989. The Flames happened to win the Stanley Cup while I was at my graduation ceremony. You can imagine the madness that ensued. More beer than any 18 year old should ever be exposed to went in my gullet. Then, everything I ever ate came out.
I never recovered the ability to drink ale.
The thought had occurred. Unfortunately, as has been shown over and again, the MX-3 community is simply not large enough to support a company on its own. I need to diversify. It's something that's been rolling around in my head for a while now.93vtecklr wrote:You should start a company with all these products you're making for us!
When you say you hate beer... do you mean megabrew beer? Because if you're including microbrews and brewpubs with real beer, you're a madman!wytbishop wrote:I hate beer.
- Gord
1996 MX-3 GS-ZE 2.5L 5spd
KLZE+LSD / Headers / KL02 VAF / Clutchmasters stage-I / Fidanza 9lb flywheel / Eibach Pro Kit / Tokico HPs / Urethane bushings & mounts / SSR Comp-C 16x7 / General Exclaim UHP 205/45R16 / Wilwood 13" brakes / Whiteline rear swaybar / Carputer / Software Crossover / Infinity components+subs / 41hz Tripath Amp9 / Trunk SLA batt / Keyless entry
That's true, however, please don't go to the honda side of life. There's a lot of cars that were not appreciated until they were almost wiped off the map. It's pioneers like you that keep these cars on our streets. Kudos.wytbishop wrote:The thought had occurred. Unfortunately, as has been shown over and again, the MX-3 community is simply not large enough to support a company on its own. I need to diversify. It's something that's been rolling around in my head for a while now.93vtecklr wrote:You should start a company with all these products you're making for us!
EDITED for off topic anecdotes.
Last edited by 93vtecklr on September 15th, 2009, 9:17 pm, edited 1 time in total.
soo back on topic
I can't wait to get these bushings... after testing the Whiteline this weekend I am convinced these bushings are going to greatly contribute to my success in autocross
Thank you Wytbishop for putting in all the time and effort into this project. You, sir, will go down in mx-3 history as a Legendary Member
- onlytrueromeo
So the whiteline bar made a big difference?
+1 I'm excited to see what the next project will be
If my understanding of suspension dynamics is correct, which I doubt, increasing the swaybar is the equivalent of increasing the spring rate...for example, pairing a swaybar with a rate of 200 lb/in with springs at 300 lb/in is the same as having a car with no swaybar and 500 lb/in springs...onlytrueromeo wrote:So the whiteline bar made a big difference?
Only for torsional force. Sway bars don't change the spring rates when both wheels move together (ie. when pitching). So not exactly the same.Flyer wrote:If my understanding of suspension dynamics is correct, which I doubt, increasing the swaybar is the equivalent of increasing the spring rate...for example, pairing a swaybar with a rate of 200 lb/in with springs at 300 lb/in is the same as having a car with no swaybar and 500 lb/in springs...onlytrueromeo wrote:So the whiteline bar made a big difference?
And it's a little more complicated, too, because the sway bar uses the opposite spring to assist the loaded spring. That is, when rolling clockwise (making a left-hand turn), the left spring is compressed by the sway bar in order to relieve the right spring.
So, if the opposite spring is, for example, variable rate, the sway bar will have a variable effect on the loaded wheel.
Having said all that, the whiteline made a huge difference for me. Mostly it improved turn-in response; when you pull hard on the wheel, the lateral feedback is instantaneous. Much less waiting for the car to roll before the turning starts. I love it.
- Gord
I have found that I have much less body roll than I did since I got the bushings dialed in. The car turns like MAD! It's pretty sick.
- mx-3_4evr
updates please!
The sleeves are about 3/4 done. I have enough of each part to start putting kits together for shipping. The first 3 or 4 shipments will go out this week in order of deposit payment date.
I only get the lathe for about 4 hours 3 days a week. It took me 4 hours to make 12 sleeves last night. 250 are required in total. I have about 60 left to do. The bulk of the remaining parts are less work than the ones I'm doing right now. I would like to have it done this week, but it will be done next week for sure.
Wow.wytbishop wrote:The sleeves are about 3/4 done. I have enough of each part to start putting kits together for shipping. The first 3 or 4 shipments will go out this week in order of deposit payment date.
- Gord
- marcdh
Ouch... That's dedication. Keep up the good work.
View Worklog
View Worklog
