I can't wait to see how you do at AutoX!
Well check out the pics in my other worklog... I didn't go as crazy with the cutting as on this one... the bar fits under the track but it won't slide underneath, I had to pull the track up then put the bar under it. I knew I was going to have to do a little work to get it in which is fineJWMX3 wrote:Nice Job mark.... more cutting than I wanted to see BUTnot bad for an experiment
i see the tip of the bracket goes right underneath the track... any clearance between or are they touching?
If i ever make more of those at least now i know to cut that angle....thanks for all the detailed pics !
well I am a n00b when it comes to chemicals but not completely stupidRyan wrote:Why would you have HCl laying around? You'll also have to be careful on aluminum wheels unless you're using really weak HCl. Al + HCl --> AlCl + H, an AlCl doesn't like water....
agreed... I was running that mod you did for a while but I just didn't trust it... I'd rather have the strut bar that was designed for the car and just happens to fit around the millenia IMNd4SpdSe wrote:Looks like the MS bar places itself very close to where my CorkSport bar goes with the fit-mod. You shouldn't have a problem even with the spacers
Was just wondering where you got the piece on the ground,for all four corners. I Went to the junk yards today hoping to get em but they were goneMooneggs wrote: I replaced:
•Both outer tie rod ends
•Both front strut mounts and strut bearings
•Both rear strut mounts and I removed the bumpstops
mikeetown wrote: Do what you want to do dude cause in the end, your mx-3 is all about you.
Trust it? I guess if you're using low grade bolts maybe, but mine got stress-tested on a daily basis with no adverse affects, not even the slightest. I will swear by that mod and those strutbars until the endMooneggs wrote:agreed... I was running that mod you did for a while but I just didn't trust it...
yeah I just got that MS barPATDIESEL wrote:nice strut bar, is that the most recent one from Ebay (a couple weeks ago?)
still waiting to see your hatch and lexan
