Yep filled through the fill hole (half way up the cyl) No dice, something bad must have happened inside.wytbishop wrote:You don't add fluid through the lock screw. There's a plug on the side of the cylinder body where you add the fluid. Let the hoist down all the way and add fluid to the plug on the side. Pump it up and let it down again and re-add until it won't take any more fluid.
Priced the replacement cylinder, it is $99.99. SOLD! Honestly spent at least 4 hours facking with it and an untold amount of Hydraulic fluid all over me, and the floor, trying to force it in the tiny fill hole.
