Page 2 of 2
Re: Idle Drop
Posted: March 31st, 2014, 7:53 am
by RX8SE3P
You can cut the valve out and use it on your new hose, that's what I did.
As for idle, I'm sure with the new IM there has to be a leak or something uncapped. Did you replace all silicone hoses, check the vacuum chambers weren't cracked etc?
Re: Idle Drop
Posted: March 31st, 2014, 1:25 pm
by Jforce
RX8SE3P wrote:You can cut the valve out and use it on your new hose, that's what I did.
Just used the old piece, works fine now.
RX8SE3P wrote:As for idle, I'm sure with the new IM there has to be a leak or something uncapped. Did you replace all silicone hoses, check the vacuum chambers weren't cracked etc?
Yeah its all new and capped.
But I replaced the coolant sensor and that did help a lot.
Still not how it's supposed to be i guess: rev - 5000, catches at 900/1000 rpm raises to 1100rpm drops to 600-700. Steady.
But at least that better than drops to almost stalling to climbing back to 600-700.
Re: Idle Drop
Posted: April 3rd, 2014, 10:40 pm
by SuperK
can you take a pic of your engine bay?
Also, how about the VRIS chambers underneath the intake manifold? They like to break, that could be a vacuum leak.
Re: Idle Drop
Posted: April 5th, 2014, 11:34 am
by Jforce
Everything was inspected before install.
![Image](http://www.mijnalbum.nl/Grotefoto-XDVI4JW3.jpg)
