Good you've got it fixed.
Fix that TB gasket as well... it will make your car run much smoother
Help my car isn't starting!! :(
- WhiteFinish
Re: Help my car isn't starting!! :(
fixed it by making a thick gasket, every OEM gasket i bought from mazda leaked. very wierd screeching sound.
Thank you guys
Thank you guys
- kulluminati777
every mazda gasket leaked?!?!
The gaskets are VERY sensitive to toque spec (which isnt even hand tight). If you dont put RTV sealant where the manual tells you to and toque it to a specific spec they will leak brand new
wow, thank you for the insight knowledge, it was cheaper for me to make the gasket and apply the silkaflex, fits perfect and not one leak.
When i do clean the throttle body i will remember.
cheers
cheers
