FOUND 2.5L ford probe engine. *PICS added*
MrMazda92
Re: FOUND 2.5L ford probe engine. *PICS added*
Post by MrMazda92 »
Fill it with sand, if added weight increases the value. :lol:
I'm kidding, don't do that...
Make it into a coffee table :wink:
wagZE
Post by wagZE »
xxxmonoxidechild wrote:Im an avid junkyarder and see KL's in yards pretty much daily. but ive never seen the dirt and dust layer up like in that 1st picture you posted. That engine had been sitting for a LONG time. im talking probably years to get like that.
but for the price, you def cant complain. and you still got the one part you really needed. and the nice part is that aluminum block weighs a ton, so you get decent money just scrapping it. :)
The problem with it is its not 100% aluminum so all I can ever get for them is steel prices.
1 mx6 88 LX auto 2.2l 4cyl
2 mx3 93 gsze bought w/ mods
4 mx3 GS SOLD-
2 pgt primered 5 spd KL SOLD
stepchyld
Post by stepchyld »
Heads and intake are aluminum, but block isn't. As scrap metal, it isn't worth much. Depending on why the crank isn't turning, it may be rebuildable. May just be seized up due to sitting so long, though some rust may be in there, depending on how long it sat exposed with no plugs.
Are you familiar with the atf trick?
93 GS, ATX to MTX swap, chrome 16x7, upper strut bars, SRD LCA bushings.
Upcoming improvements: Tokico/Eibach struts/springs, energy suspension LCA bushings
94 RS MTX, Engine swap completed, ALIVE Again!
95 RS ATX, parts car/project X
kulluminati777
Post by kulluminati777 »
Nd4SpdSe wrote:Make it into a coffee table :wink:
hey bro are you selling your table? i seen somebody post up a Kijji ad or something like that and it looked like yours
scorpio_vette
Post by scorpio_vette »
MrMazda92 wrote:Tear it down... Keep at a bear minimum the valvetrain. I'd say part it out, you may help someone out, and put a little money in your pocket for other projects/repairs. :welder:
That's one of the ideas I was playing with
wagZE wrote: The problem with it is its not 100% aluminum so all I can ever get for them is steel prices.
If you want the most for scrap, you have to take the time to strip every single separate piece of metal apart. you basically need to turn the engine into separate piles of aluminum, copper, brass and steel (and/or any other types of metal).
stepchyld wrote:Heads and intake are aluminum, but block isn't. As scrap metal, it isn't worth much. Depending on why the crank isn't turning, it may be rebuildable. May just be seized up due to sitting so long, though some rust may be in there, depending on how long it sat exposed with no plugs.
I was thinking along those same lines, that the engine most likely would be salvageable and I could re-finish it over time.
I am familiar with using ATF to clean engines before an oil change. but i don't think that's what you are talking about.
Oh hell no! Link? If my room mate was selling it on me (I'm gone on exercise) I'd have an obituary posted in the news paper and his stuff on Kijiji when I get back.
kulluminati777
ill look, im sure it was on kijiiji or gumtree
