Removing EGR?
Re: Removing EGR?
crazycanadian wrote:Removing the EGR system wont make your code go away... You have to figure out if it was wired up right and if the vacuum lines are right... Even if you have the egr valve plugged in but not opperational you'll most likely still throw an EGR code...
:2thumbsup:
