Suddenly noisy KLDE(FIXED!!)
atx_mx3
Re: Suddenly noisy KLDE
Post by atx_mx3 »
MrMazda92 wrote:
RX8SE3P wrote:It defies all logic to say the klo1 cammed engine can make the same power as a kl31 which pushes the power band higher in rpms in order to make more power.
In a sense, assuming they're both "stock" or relatively so, this is correct.
RX8SE3P wrote:one camshaft tops out in the 5k rev range and the other goes to 6500.
This is definitely in need of clarification. The relationship between lift and duration determines where the power is made, not necessarily how much power is made. Power higher up doesn't necessarily mean MORE power. It simply means maximum power is achieved higher up.
In this case, it's correct(barely), but it is not a general rule to be followed... Just saying it so nobody takes the information too far off topic :P
Thanks for clearing things up! :freak:
So i said it had tons of power....today i experienced a power loss.....significant one. I will check the codes to see if anything new came up. I have a sneaky suspicion that this motor is going to die soon. 2 more days......
1993 Mazda Mx-3 GS-Sold :(
1992 GS "The Bucket" Gone.
92 GS 5spd for sale! Sold it....after I got a hatch cover in great condition :evil:
MY WORKLOG, check it out :) viewtopic.php?f=46&t=79959
RX8SE3P
Post by RX8SE3P »
Thanks. My main point for KL engines is when comparing two identical KL's - the one equipped with kl31 cams will always make more power.
@ atx_mx3 - I suggest trying to keep the engine going for as long as possible whilst you do up your ZE if you get one. Then you can take your time and build a very reliable fast engine. Big loss of power, could be timing has jumped, in which case wytbishop is correct. Or knock sensor. Code check is in order :)
1995 Eunos 30x KLZE
atx_mx3
Post by atx_mx3 »
I have stopped revving it past 4k. I am going to check codes today, see if something new popped up. Ideally, what I would like to do is: Get the KLZE, make it fresh. Swap it, then take the DE and make it fresh too. Doesn't hurt to have a spare motor laying around. Especially with these finicky K series....
atx_mx3
Post by atx_mx3 »
Well, no Ze's are coming in on the container tomorrow. So no ZE for me....for now.
I checked codes again. Same 8 codes:
2
15
16
17
23
24
69
RX8SE3P
Post by RX8SE3P »
Wow lot's of codes. O2 sensors will fix four of those codes. Rockauto.com has fairly cheap stock sensors, which are OEM denso's.
DENSO Part # 2344143
DENSO Part # 2344606
Code 2 is crank angle sensor. http://www.mx-3.com/manuals/showimg.php ... F2-077.gif
Another is EGR, which is code 16. Manual says open or short circuit. May not even be connected from engine swap?
Code 69 should be the engine coolant sensor, they call it water thermosensor. This will make you run rich as hell and lose power. When mine buggered up I chewed lots more fuel and had lots less power. Fix that first, then see if that helps the O2 sensor codes. Then do O2 sensors and the others IMO.
1995 Eunos 30x KLZE
atx_mx3
Post by atx_mx3 »
Thx RX8SE3P for being active in my thread and giving me useful info.
The motor is a KLDE but its running on a K8 ecu. The spot where the temp switch would go(on the K8) is flat on the DE....It looks like they used nothing from the k8 and everything from the mx6 or probe they got the motor out of.
RX8SE3P
Post by RX8SE3P »
No problem mate, glad to be of some sort of help!
Seems you would have a 94+ engine and your mx3 is a 93. The 94 and later engines drop the extra coolant temp sensor and just use one. This could play some part in the code. Best bet is a 94 KLDE ecu, then it won't look for any extra coolant sensors.
Make sure you don't go 95 for the ECU as the distributor wiring is changed over and you won't be able to start the car without swapping wires.
1995 Eunos 30x KLZE
MrMazda92
Post by MrMazda92 »
Awesome guys! Good to see progress here, I've been kinda lurking for a few days. I agree about the Cam thing too btw, I just wanted to go a little more into the topic, so others reading this down the road got a clearer picture of what they do! :)
atx_mx3
Post by atx_mx3 »
KLDE ECU it is. I don't mind having to tap the filler neck and putting the sensor in...but I think this motor needs the right ECU...even if it does blow up soon.
More troubles...So today I'm driving it home after sitting all night and most of the day, I have NO power past 3.5-4k. It miss-fires badly. The tachometer is also erratic....faulty ICM?
*Edit- It's about time to get rid of the OEM ICM, having had the same issues with my first Mx3 GS. Ill be buying/installing the HEI ignition module in the morning ...eliminating 1 more variable.
atx_mx3
Post by atx_mx3 »
Was able to get a BRAND NEW distributor to test on my car. The horrid miss fire went away, but still not power past 4k. I am going to take it back to the owner and do the HEI mod...will keep you guys updated.
EDIT- Put the old distributor on the vehicle and did the HEI mod. Miss went away...still no power past 4k. Pulling the timing covers...
atx_mx3
Post by atx_mx3 »
wytbishop wrote:I bet it's the timing belt tensioner. Either way you are probably going to have to do some disassembly to find it.
wytbishop FTMFW!@!@!!
I took the covers off and started it...belt is flopping around like crazy.......2 teeth off on the crank. Tensioner will be here in 2 hours...re set timing...report back.
atx_mx3
Post by atx_mx3 »
New tensioner=awesome. Car got almost all the power back, NO MORE NOISE. Even the HLA noise I originally (thought) I heard, gone.
Thanks a TON guys!! A/C next....100+ degress here in TX on a regular basis...
:love2: :love2: :love2: :love2: :love2: :love2: :love2: :love2: :love2: :love2: :love2: :love2: :love2:
Re: Suddenly noisy KLDE(FIXED!!)
Almost better than sex eh? :2thumbsup:
RX8SE3P
Post by RX8SE3P »
Lol and you were so quick to start looking for a ZE :lol:
Glad your got it sorted mate.
Imagine the power you will have if you fix all your errors and run a DE ecu (if you have not already) :freak:
1995 Eunos 30x KLZE
atx_mx3
Post by atx_mx3 »
Daninski wrote:Almost better than sex eh? :2thumbsup:
ha
Now I wouldn't go that far...Im married to a 100% Viet girl. :o :o
RX8SE3P wrote:Lol and you were so quick to start looking for a ZE :lol:
I just needed an excuse! :mrgreen: Im glad I didn't have to spend $800 and the man hours to do it...but the extra power sure would have been nice.
Im buying the ECU and VAF from a user here....Lets see how nice I can make the DE since she didn't blow up.
AGAIN THANKS FOR THE HELP GUYS! :love2: :love2:
