Actually 2 questions...
1) The correct firing order is from left to right --- 1 top 2 bottom 3 top 4 bottom 5 top 6 bottom (also right beside disty) correct?
2) My car wouldnt start today... at all... which I've never had a problem with until after I cleaned the throttle body. Would adjusting the screw on top help? I know I should be more technical but Im not good at that stuff. I will let yall know what happens. I bought NGK plugs XD
Oh and Ryan....
I will check the timing next before disty. I appreciate your advice. It is my next step. I just read your comments after buying the wires so... hopefully I wont need to do your step.
Dan.
The Cap checked out ok. No problems. I took it to a mechanic before you mentioned it and he looked at it and said it was ok. I filed it down just barily on the tips... and by barily I just mean swish swish and it shines. Thats what he said anyways, make sure there was no oxidization on the tips.
