Gas Tank Leak?
cWs306
Re: Gas Tank Leak?
Post by cWs306 »
Yah im thinking its moisture/condensation. cause it was cold the night before but while running nice and warm i probably built up so much moisture from the roads that its just leaking off. im gunna go take off my hood insulation stuff, see if that helps. after that ima cruise her to my garage and get her up on a jack n see. :shrug: hopefully it checks out just to be moisture.
Ryan
Re: Gas Tank Leak?
Post by Ryan »
Check out your inner fenders. Open the door and look between the door and the car, into the area over the mud guard. See if that is all full of leaves and dirt and stuff.
cWs306
Re: Gas Tank Leak?
Post by cWs306 »
uhhh, ive never noticed any hole or opening in my fender. but ill go check anyways! thanks.
cWs306
Re: Gas Tank Leak?
Post by cWs306 »
old post, totally forgot to let yah know what my leak was.. IT WAS MY BATTERY!!!!!!!!!!!! the sob blew up man! literally the bottom of it was effin melted.. looked on my battery tray and it was like full of liquid. looked under the car and it was coming right from it. took the battery out and theres been no leaking substance since. not even a year old battery.. canadian tire replaced it yesterday tho, thank god.
Re: Gas Tank Leak?
That strange leak under the drivers side engine area,,,maybe someone had a whiz and you parked there next. Hope you didn't taste it.
cWs306
Re: Gas Tank Leak?
Post by cWs306 »
hahahahaha! :P i gotta admit. i did taste it. but had no taste to it. accept my tounge tingled a little bit. which lead me to believe it was the battery acid. also when i was taking the battery back n carrying it into the store. you know how to shake them and u can hear the liquid swish around. yah well there was like 0 swishing hahah.
