Rough Idle/Stalls when braking... (putt putt putt putt putt)
- Ryan
Re: Rough Idle/Stalls when braking... (putt putt putt putt p
Try a new used VAF....
the last time i had this happen to me i had a burnt valve. if it hasnt had a valve job in a while you may need one. also ive had the same problem when the vics, egr, and idle air bypass were all disconnected (they must be crazy asking for $600 ea). check linkages, hoses to each and do a compression test.
1994 MX-3 1.6L B6DE 16v DOHC - rear disc swap, nix power steering/ac, Corksport f&r strut tower bars, Pedders urethane control arm bushings, urethane motor mounts, steel braided brake lines, painted dash, protege tranny
90 Miata w/ b6, Konig Lightspeed rims, Cams (boost to come soon)
74 Porsche 914 w/ 1.8L - restoration prooject
Inside of my pistons
http://www.pix8.net/pro/pic.php?u=2838Ipxto&i=11562371
Old headgasket
http://www.pix8.net/pro/pic.php?u=2838Ipxto&i=11562372
Valve side of the head.
http://www.pix8.net/pro/pic.php?u=2838Ipxto&i=11562373
These pictures were taken when I did the headgasket a few months ago. The valves looked fine then, and I've done my best to keep the engine in good shape.
MAF/VAF These do the same job, but different ways on different years right? I thought there was a wiring issue with swapping these? I do have 2 airflow sensors. I've tried swapping them without any difference.
Stock MX3, still on the car. http://www.pix8.net/pro/pic.php?u=2838Ipxto&i=11562375
Leftover from Tracer LTS. http://www.pix8.net/pro/pic.php?u=2838Ipxto&i=11562374
Ryan, in your parts pile posting; do you still have the speedo cable?
Old headgasket
92 RS BP05
93 GS KLZE
92 RS BP05
93 GS KLZE
- Ryan
I see maybe 5 burnt valves...
See where they're only black on one little portion? Thats a bad sign.
S code is for the 1.6L's and the B8.
U code is for the BP.
I no longer have the speedo cable... I think. I can check for you, but it made noise in cold cold weather (-20C or more)
What are your compression numbers?
WOOT! +5 hp for meRyan wrote:I see maybe 5 burnt valves...
sucks youll have to pull the head off again...
- Ryan
It would be cheaper to buy a new B6 with good compression than to get those valves repaired.
?Why would I buy a B6? I like my powerless BP...
I found a BP05 head for $225 after shipping. It's in Spokane, so it'd ship here quick.
BUT am I asking for problems if I hold off on rebuilding the bottom end until I have enough cash to do so?
I figure since I don't have a core on the head I can rebuild it while the old one is going out; and then buy a block and rebuild it... (but that might be months out)
And I still haven't done a compression test. Harbor freight has cheap testers right?
I figure I could get a gasket set, rebuild the head, port and polish and then put it all back together. Maybe some performance stuff too.
Northwest Cylinder Head is dedicated to providing the highest in quality rebuilt cylinder heads. We operated a full head shop, and rebuild anything from cast iron v8 heads to newer import and domestic aluminum heads. We use the newest techniques and equipment to ensure our rebuilt heads offer your engine a new extended life. There is never a core charge or core return on any of our purchases. We offer a straight no hassle sale, to get your rig back on the road.
Interchange
Fits 91-97 DOHC 16-valve with BP05 casting number
The head is complete with valves, springs, cam and rockers installed. You will need to use your cam gear and cam seal.
Warranty
We offer a 6 month unlimited mile warranty.
92 RS BP05
93 GS KLZE
92 RS BP05
93 GS KLZE
