ok, so ive come to the conclusion that my Check Engine light is MESSED!
It use to just flash all the time.
now, its all over the place.
When i changed my alternator, it went away for 2 days.
When it came back, it was solid. no flashing.
then it went away again the next day.
the day after that it came back.
today its flashing again.. AHHHH@ lol
i'm going to try to jump the two together to get the codes if i figure out how to do that.
where are the pins i need to jump? under the hood neer the firewall?
Check Engine Light NEVER Stops Flashing.
Re: Check Engine Light NEVER Stops Flashing.
theres a little black diagnostic box. you need to jump Ten and ground
Ignition On, Engine Off?mikeinaus wrote:theres a little black diagnostic box. you need to jump Ten and ground
yes, keep the ignition ON but engine off. It will blink in a series. Search for CEL codes to get detailed info.
'94 MX3 GS (black)-- 2.5L DE w/ straight neck IM, SSAC Headers, KYB-GR2's, Intrax Springs, CM Stage I clutch, OBX STS, filled front & rear mounts, CAI- SOLD ![Sad :(](./images/smilies/icon_sad.gif)
- RS_OBD'oh_2
get a damn obdii code reader
