Page 2 of 2
Re: K8 rebuild question
Posted: May 24th, 2010, 7:57 pm
by Nd4SpdSe
valk1317 wrote:would have to be a canadian seller. shipping anything into canada is rape. if i baught a klze on ebay or a import shop, sure id pay $700 for the motor but another $250+ in shipping and duties.
a used motor from another user wouldn't be that much better.
There are MANY engine importers in Canada, no need to get one from the US. They do offer warranties on them. The reputable shops (like Japan Auto) do charge a premium, but they'll do the motor deinstall/reinstall free of charge if it is defective.
Posted: May 24th, 2010, 11:37 pm
by valk1317
this is how she sounds and runs right now. the smoke clears when it warms up and the motor runs pretty well though still knocks.
http://www.facebook.com/v/1467556617192" onclick="window.open(this.href);return false;
Posted: May 25th, 2010, 5:55 pm
by SpatialTerror
i would have to say that is a bad valve guide.
its what caused my motor to go.
and just recintly caused my buddies motor to go.
oh well i got a klze now and here in like 5 days were ordering him a klde
Posted: May 25th, 2010, 6:19 pm
by valk1317
AWeeesome. So i guess there isnt a sleeve i can replace to fix that? New head basicly?
Would a kf engine swap in easily? Maybe i should just run this til its dead and hopefully we have another car for her and i can jack it and gut it for a kl then.
Posted: May 25th, 2010, 11:38 pm
by Ryan
a machine shop/head shop can replace a valve guide no problem.
If thats what it is.
Posted: May 25th, 2010, 11:47 pm
by valk1317
so what do i do to check? take off valve cover and wiggle the valve?
still curious if a kf will drop into a k8 car. cheapest motor I have found is a k8ze and kfze for 450 in toronto.
Posted: May 26th, 2010, 12:02 am
by Ryan
450 for a low K motor would be decent.
you can't really check valve guides without pulling the head.
If it burns a lot of oil at startup, its usually valve guides. The oil pools on top of the valve, and when you start it, it drops in. It burns off all at once, and doesn't leak much once its running.
You could remove the I/M and check the intake valves for oil pools. Thats fairly easy.
Other diagnostic techniques are mainly experience. Knowing exactly what the sound is, etc... that a cam noise will have a 2x faster repeat rate than a bottom end noise...
Posted: May 26th, 2010, 12:19 am
by valk1317
I might check that out soon then. it does smoke for several minutes and doesn't really stop until it warms up fully.
Thanks for the help so far everyone. I'm not a mechanic by any means. just a hobbyist.
Most complex thing i've done so far is change the clutch on my msp myself.
The woman isn't all the keen on a engine rebuild or spending a bunch of money on repair parts, but is willing to take it to a mechanic just to find out whats wrong with it.
It sucks, cause its in good shape for the most part but smoking so badly, we would be lucky to get 1k for it at sale which seems like a waste =(
Posted: May 26th, 2010, 12:20 am
by Ryan
Just warm it up before the showing
Posted: May 26th, 2010, 12:32 am
by valk1317
ha ha. we actually did that when this one chick was gonna come look at it. turned out to be a flake and never showed up, but called a week later to look at it again, and guess what =D.....
not much interest since.
The more I look at it though, the more im reminded of when i was 15 and wanted one of these pretty bad ha ha. id like to buy this car off her and track slut it with the most bad-a-- kldet swap.
seen a lot of them for sale and even the 94/95 ones are in really crappy shape. this one just has a dent on a quarter panel i can fix, a fresh coat of paint, new struts/tires ect.
Could do it pretty cheaply too. parts for the msp cost a lot and you need a s----ton of money to make any real power on it.
A bpt swap is also a possibility but would take more work.
ah well. ill check for oil pools when i get a chance. it isn't getting driven all that much for now so im sure it will last a while.
