go buy a obd2 code reader from your local auto parts store. and plug it into your car.
it will give you a code. that code will tell you whats wrong with your car.
'96 Eunos V6 Idilling problems - Help Please!
- SpatialTerror
Re: '96 Eunos V6 Idilling problems - Help Please!
SpatialTerror
SpatialTerror
- Newfie_dan
obd2 does not mean that it registers all problems, it is helpful in getting information from the ecm for instance my coolant temp sensor was seriously out of whack but it did not throw a code for it. obd2 is not a be all end all for doiagnosis.
- SpatialTerror
very true.
but it makes figureing out where to start alot easier and a bit more percise
SpatialTerror
SpatialTerror
No need to since i know what the problem is, the only issue now is deciding whether to get a stock oem part or convert it to a cold air intake?
1996 Mazda MX 3 V6
- SpatialTerror
well why not convert it?
i mean your already gonna have to spend money.
might as well right?
SpatialTerror
SpatialTerror
Anu suggestions on what to get as im in the dark regarding this and you read posts all over the place saying this and that.
1996 Mazda MX 3 V6
- Newfie_dan
go with a cai its cheaper and will last longer than replacing the stock crap, read this link http://www.mx-3.com/phpBB3/viewtopic.php?f=15&t=44545 it lists what you will need to get from ebay to make it work.
