Probably did some serious damage...fml.
navymx3
Re: Probably did some serious damage...fml.
Post by navymx3 »
Mnemonic wrote:You must got find an a-ganger
um....what?
93 Mazda MX-3 GS V6 24V 5 Speed
_-Night-Shade-_
Post by _-Night-Shade-_ »
LoL JWMX3 can see the future! Fail #2! Hahah
mitmaks
Post by mitmaks »
Daninski wrote:Are you sure that's gunk in the bottom of the spark plug hole or could it be the end cap off a spark plug wire?
that's what Im thinking. Probably that rubber insulator piece at the end of hose
navymx3
Post by navymx3 »
navymx3 wrote: I worked on it last night, and found that it was in fact, the rubber end of the spark plug wire. So I got that out with a small metal pick, and changed out the spark plug finally...
Then I took back out the TB, and put that PCV line where the coolant line was, and put it all back together and fired it up...I figured that had worked...but not until i drove to work this morning...About half was there, my engine started smoking, and there was a big could of smoke trailing my car.
I didnt know what had happened, I just figured it was from the collant and water that got on my engine that night. Nope.
I got to a gas station on base, and checked it out, the PCV line had broken and the collant was pouring out again... :(
IDK where I can go to get the proper hose to keep that from happening again...
mitmaks
Post by mitmaks »
go to parts store and they should be able to sell you a piece of proper size hose
Ryan
Post by Ryan »
This thread is funny :)
navy, you're a nice guy and all... but I don't understand how these things are escaping you.
navymx3
Post by navymx3 »
Neither do I ryan..lol. my weekend has been really bad to me...lol...Im taking the car to pepboys on monday to have them give me a wheel balance and alignment, put a hose on my IAC, and see if they can fix my rolling idle problem. but thats only if i can make it home tonight...lol
