Page 2 of 2
Re: KLZE FINALLY!!
Posted: May 2nd, 2009, 12:13 am
by SmoothMX3
I'm running the mx-6 ecu and vaf ... runs alright to me.
Re: KLZE FINALLY!!
Posted: May 2nd, 2009, 10:51 am
by kast2L
Legato626 wrote:So after installing the engine would it be safe just to wait for the KL31'36 ecu before driving it?
i would say yes
Re: KLZE FINALLY!!
Posted: May 2nd, 2009, 11:01 am
by onlytrueromeo
Well you'd be fine to drive it until you get the parts...it ain't gunna hurt it to run it a bit rich, you just won't get the same performance.
Re: KLZE FINALLY!!
Posted: May 2nd, 2009, 11:36 am
by Nd4SpdSe
Really it doesn't matter, it just runs really, REALLY rich, so you'll be burning alot of fuel, so don't expect the best gas milleage. If you run it long-term, you'll burn out the cat and your plugs probably won't like it either, but many people have run K8 ECU/VAF combo's, either temporarilly or even for a while because they bought a car that was pre-swapped and didn't know, but either case, I've never heard anyone mention any negative long-term side effects from that setup.
Re: KLZE FINALLY!!
Posted: May 2nd, 2009, 8:45 pm
by Legato626
Well so far everything is swapping to the new engine fine so I am good for now. How does the wire harness deal with the ZE are there a few plugs that I am not going to use? And I seen the fuel lines run different to.
