New guy with a 95
Re: New guy with a 95
I'm still undesided on the turbo. I was just looking at how much i can pull from this motor on a N/A build. I have the turbo just sitting in the garage so i might just put it on.
mzdamx3rsdohc
for a n/a build i dont think anyones really gotten into it too much.
ive been curious about this to as a b16 up till vtec makes the same power as the b6de or very close, but when vtec kicks in its engaging a different lobe on the cams with more lift and duration. vtec is there so you dont lose your low rpm drivability by only having a agressive cam. mind you it has higher compression to and probab;ly a different stroke.
but with stage 2 or 3 miata cams with cam gears
higher compression pistons
5 angle valve job
oversized valves
titanium or stronger valve springs retainers
knife edged crank
custom intake manifold without vics
bored throttle body
engine management
better ignition system like a msd
2.0 probe header
i dont see why a b6de couldnt make 160-170 at the crank, but youd lose all your lower rpm driveability and it would be very costly
i saw a post where JOSH(i think) had a b6de with miata cams and vj-14 at 14psi and im positive he put down 230whp
so turbo would probably be your best way to go-
i think all you need is:
bigger fuel pump
1st gen probe mx6 injectors and turbo
intercooler
piping
BOV
engine management
oil feed oil return, etc.
and at 6-8 psi youd in the 14's depending on your drivetrain, driving- at least thats what i read in his post he ran a 14.1 at
i may be wrong im sure someone here will chime in also
5 angle valve job
oversized valves
knife edged crank
bored throttle body
engine management
2.0 probe header
bigger fuel pump
intercooler
piping
BOV
engine management
dohc b6, intake, exhaust, miata cams ready to go in
