Daninski wrote:With the exception of droppinig the hood on your head in front of that foxy looking Babe. lolnightfire wrote: Except for the block the KLZE is quite different. It uses higher compression pistons, and different heads and cams. It's 2.5L (the extra torque is great) and the power surge continues well up into 7000rpm. It’s the single best thing I ever did on my car
first modification what has the best power gains?
Re: first modification what has the best power gains?
- Gord
1996 MX-3 GS-ZE 2.5L 5spd
KLZE+LSD / Headers / KL02 VAF / Clutchmasters stage-I / Fidanza 9lb flywheel / Eibach Pro Kit / Tokico HPs / Urethane bushings & mounts / SSR Comp-C 16x7 / General Exclaim UHP 205/45R16 / Wilwood 13" brakes / Whiteline rear swaybar / Carputer / Software Crossover / Infinity components+subs / 41hz Tripath Amp9 / Trunk SLA batt / Keyless entry
