I do that and its works fine. I just eliminate that line and jumped the line with a rubber line and wala!!nos92mx3 wrote:IIRC that line in front is just a power steering cooling line. I **THINK** its low pressure so you can just cut the line and replace with a smaller rubber section, and some hose clamps.
intercooler help
Re: intercooler help
- johnmx3ze
you dont have to take it off do like i did...
![Image](http://i470.photobucket.com/albums/rr69/johnmx3ze/DSC01781.jpg)
![Image](http://i470.photobucket.com/albums/rr69/johnmx3ze/DSC01595.jpg)
[imghttp://i470.photobucket.com/albums/rr69/johnmx3ze/DSC01626.jpg][/img]
![Image](http://i470.photobucket.com/albums/rr69/johnmx3ze/JonNEWsignatureVredSMALL.jpg)
- RS_OBD'oh_2
DO NOT replace power steering fluid with just any old hose. PS fluid reacts with heater hose. The section replaced MUST be certified for PS fluids.Bo0sted_Rafi wrote:I do that and its works fine. I just eliminate that line and jumped the line with a rubber line and wala!!nos92mx3 wrote:IIRC that line in front is just a power steering cooling line. I **THINK** its low pressure so you can just cut the line and replace with a smaller rubber section, and some hose clamps.
For more info see Dsportmag Vol.70 October2008
- onlytrueromeo
The best way to go manual steering is with a 323 Rack. (Use the search with that). You CAN just cut the lines and take off the pump, but its not the best way. The 323 Rack does have a longer lock to lock ratio though.
