Haha, Ive noticed this aswell. I just didnt say anything.whats the hell cams are you runnin Juan kl36????
[STICKY] How to rebuild a hydraulic tensioner for under $10
Re: [STICKY] How to rebuild a hydraulic tensioner for under $10
- fowljesse
"How did you do that?
You should do a write up."
It was too easy for a write up. I didn't think about it. I'll try to remember, though. I just used a hydraulic ram with some washers, and such, to make sure I was pressing on the outside if the bearing race, and not putting pressure on the bearings themselves. I got some high quality sealed bearings at a very good local parts store (6006 seems to pop into my cloudy cranium), and pressed them in the same way. You could use a C-clamp to press them, if needed. I wish I knew about the tensioner mod then!
When I mention stretching, I'm assuming hundredths of an inch.
fieromx3 wrote:the original way possted on pt juan is u get a shorter bolt and tap the bottom and thread the bolt in through bottom and pushes the ORIGINAL hydralic arm up not a bolt through the hole dam thing... thats how mines done and been done for like 1.5 months
Thats another way to make a manual tensioner
I havent modified mine yet
2008 Mazda 3
1993 MX3 GS
1993 MX3 GS
