Page 2 of 2
Re: Which Oil Is Best For Mazda Mx3 1993 That Burns Oil
Posted: June 26th, 2008, 8:55 pm
by ElectricEnergy
Hahah, yes. I did timing belt, water pump, most the gaskets/seals, acc. belts, clutch/flywheel (you have to do this one, the stock clutch wont handle the motor). and some other basic stuff.
I think the project ended up costing around $2200-2400 in all.
Posted: June 26th, 2008, 8:58 pm
by Ashton Janzen
I dont have a stock clutch i redid it when i bought the car.
Posted: June 26th, 2008, 9:18 pm
by ElectricEnergy
That'll take a pretty big chunk of the cost out then. Which one did you go with?
Posted: June 26th, 2008, 9:28 pm
by Ashton Janzen
dont remember. costed 900 bucks tho
Posted: June 26th, 2008, 11:17 pm
by solo_ryder
Yea, just replace them along with the timing belt tensioner and new timing belt belt bearings.
I am guessing you are in the vancouver area?
Posted: June 27th, 2008, 12:34 pm
by Ashton Janzen
No i am in saskatoon.
Posted: June 28th, 2008, 2:33 pm
by Ashton Janzen
hey david could i get you to just do it for me and i will pay you in full. that would be so much easrie for me.
Posted: July 15th, 2008, 10:25 pm
by blaudust7
Just keep your eye on the oil level and find out when you need to change. I burn a little bit of oil too with the K8 and change oil about every 1700 to 2000 miles. I use 5w30 with 219,000 miles and the car still runs great. I have used some stuff called AutoRX. It seemed to help a little.
