Im done
hgallegos915
no, i was detonating with the stock ze injectors and fmu, its a cosmo afpr. Not siue if its rising rate.
-hec
- XxantwawnxX
An FMU(in the traditional sense,vortech ect..) is nothing but a Rising rate fpr . Dif name same thing. http://www.racetep.com/begireg.htmlhgallegos915 wrote:no, i was detonating with the stock ze injectors and fmu, its a cosmo afpr. Not siue if its rising rate.
hgallegos915
300 miles and driving fine. Except clutch is going, got my replacement from wagze tho. It doesnt smoke at all anymore. yepee!!!!
-hec
- se7en
nice work Hec!
I hope to say the same thing in the upcoming weeks.
7
btw: are you using the ebay turbo?(t04h)
7
hgallegos915
yeah I am, the plan is styill to replace it. after the clutch thats the next thing, then i can start megasquirting and up it to 7 psi.
Removing vris this weekend.
The ebay turbo was good at first but the seals were to crappy for the oil pressure restrictor i had and a small oil drain line. When i got it inspected at a shop, they said the middle was good, so were the bearings, i replaced them for garret internals except the shaft , (had that inspected) and its good.
Still its wise to change it out for a name brand.
Dont forget the oil drain line, thats VERY VERY important lol. My priginal line was to small, even a number 2 pensil could not go in the bung.
-hec
- se7en
...about the oil pressure restrictor, what did you use?
also, is it hard to change the seals?
one other thing, where does the boost start coming in with this turbo?
thanks
7
ps, I sure hate waiting for ebay stuff to get here. In canada, everything takes forever!!
thanks
7
- PWRD_BY_HKS
my smokes for the first minute or so... white.... really white... then chills out ... then i drive it... and i hit boost and it smokes again... after that... coast is clear no smoke no nothin.... those garrett people and their humor....
jdmx-3 KID OF THE
VICTORIA RACING
ZE PERFORMANCE IN 915 TX
Kl01-ZE,Kl31 ecu, millenia manifold, ngk plugs, ngk wires, probe tranny/ and clutch (stock), VortecH FMU 12:1, Aeromotive AFPR, Tial .38mm Wastegate w/ 4lbs spring, Walboro 255 pump, AiResearch T4, 3" down pipe, GODSPEED manifold, Spearco Boost Gauges, BF Goodrich G-force drag radials.
14.8 1/4 mile all motor untimed on boost.
VICTORIA RACING
hgallegos915
yours does that too? that makes me feel good (not beucas of the flaw) but because i guess its normal. Mine does the exact same thing dude!
one thing.. my idle sucks... i cant get it to stop flucutating..
also I get a cel and when its on, my afs rise to 10. i step on it a bit and then it goes away and afs cruising go back to 14.
i had pulled codes and it read o2.. bleh!
oh and its been drinking gas like water.
-hec
- PWRD_BY_HKS
i have some codes i gotta take care of.... my o2 sensor being one of them....
jdmx-3 KID OF THE
VICTORIA RACING
VICTORIA RACING
!vtec-this!
mine smokes like a champ to damn ebay turbo's they sux.PWRD_BY_HKS wrote:my smokes for the first minute or so... white.... really white... then chills out ... then i drive it... and i hit boost and it smokes again... after that... coast is clear no smoke no nothin.... those garrett people and their humor....
not to mention all the oil in my intercooler piping
http://profile.myspace.com/index.cfm?fu ... d=77496445
My Car: Mazda MX-3 v6
14.5 @97mph
2.328 60ft....still more room for improvement
Only 165whp
Now boosted & New #'s to come
14.5 @97mph
Only 165whp
hgallegos915
I dont have oil in the intercooler piping tho... rebuilt it!
-hec
lol u guys want to talk about smoke... when the seals entirely went on my brand new garrett t3 (too much oil pressure took out the seals i think) i had a stream of oil running out the exhaust like a river.... i droped about 2 quarts on the road in 10 mins of normal driving....
Thought maybe the little k8 finally went at boosting over 15 psi....
but nope perfect compression across the board.
http://www.cardomain.com/ride/2433610" onclick="window.open(this.href);return false;
mx-3 Kl Turbo (Weekend/show car)
95 talon tsi awd (Daily Driver For Sale 6,000 or Trade for a Mx
1989 Cbr600 (StreetFighter/Stunt Bike)
1967 Winnebago Motor Home (Pimped out Party Bus a friend and I went in halfs on)
1972 gremlin X Turbo Diesel
, 1999 VR4 Fathers Cars that i end up working on and drving alot
hgallegos915
I think thats most of our problems, is we dont know much about boost and most people forget to mention that crappy turbos require a restrictor. I got mine off ebay, its like a connector that has a pin size hole and thats where oil comes trough.
-hec
hgallegos915
hey guys, i got some questions..
The brake booster.. thats getting boosted.. that ok?
now i am in process of removing vris, one was easy, two is a bit hard but ill get it. I block off the vac canister right?
Also one thing thats happening.. i dont know why.. the car is warmed up, then it shuts down. So i start it, idles fine for 15 seconds, then it cuts out, tried uping the idle.. no dice... what can it be? I got no leaks in the intake.. you think it can be vaf related?
-hec
- XxantwawnxX
the brake booster does not get boosted if u hooked it up right...theres a factory one way valve in it.hgallegos915 wrote:hey guys, i got some questions..
