Hey guys what do you think of the one i built, i'm not sure how it will run but i made it sothe angle of the pipes is the exact same as the angle in the b6de cyl. head ports and the pipes are the same as the ports as well. the runners are 6 1/2" long and I made velocity stacks at the end. the pipe tha joins all the smaller pipes together is 3" ID and i used a 65mm thottle body for it. I should have it running within an other week or 2 let me know what you guys think.
http://www.cardomain.com/ride/2443642/2
custom intake manifolds for B series
- 10secSim
B6 1.6L DOHC, CAI, custom intake mani. with internal velocity stacks, 65mm thottle body, probe 4-2-1 header, custom 2.5" high flow exhaust, Centerforce dual friction, MS2, MSD 6A, Tokico struts, EIBACH springs.
http://www.cardomain.com/ride/2443642" onclick="window.open(this.href);return false;
