Nd4SpdSe wrote:No. What they did is do a "2-speed idle test", "2-speeds" technically being that you can't hit the right RPM range at the cruising speed they would test at, but that's the test they would classify your as so that it ignored the roller test. The earlier rollers were on ramps and sat high, and shops wouldn't risk damaging your car, so they did it that way. Last on they moved to low profile rollers in the floor with no ramps.Josh wrote:Nd4SpdSe - Can they not pass you for being too low?
Now, they're revamping the system, basing it on OBDII code scans only, and for cars 88-97 (typically covering all pre-ODBII vehicles. 87 and older exempt) will require an idle test only.
A decision has been made to make amendments to Ontario Regulation 361/98 (Motor Vehicles) under the Environmental Protection Act. The amendments to the regulation will modernize the Drive Clean program, and include implementing computer based emissions testing for light duty vehicles.
The amendments prescribe new On-Board Diagnostic (OBD) emissions test standards and emissions testing equipment for 1998 and newer light duty vehicles, and prescribe two-speed idle (TSI) tailpipe test standards and emissions testing equipment for 1988 through 1997 model year vehicles.
The current dynamometer test and emission standards prescribed in section 9 of the regulation will be revoked as of January 1, 2013. In addition, the regulation will be amended to provide the Drive Clean Director the ability to enhance repair technician training and effectiveness.
The proposed regulatory amendments will ensure that the program continues to be effective in reducing harmful vehicle emissions of smog-causing pollutants such as nitrogen oxides (NOx), hydrocarbons (HCs) and particulate matter, as well as carbon dioxide, a greenhouse gas.
This is how Washington is now, OBDI and older only require idle test and OBDII is a plug in affair. But you will fail every time if you have a tech light on in the dash. the wife's car had an issue with coolant sensor and kept throwing a code so I wiped the codes a block down the road and passed like a charm. My car I just register at my folks and never have to go
